difference between obd2 and obd1 distributor
Old Jul 9, 2006 | 10:18 AM
IVI's Avatar
IVI
Default difference between obd2 and obd1 distributor
What is the difference between an obd2 or obd1 distrubutor? How do you find out which one you need?
Also is there a difference between the different b-series motors available?
Old Jul 9, 2006 | 10:35 AM
projectTeG's Avatar
nothing internally, but the plugs are different, they have the same amount of wires, but the obd2 has one plug and the ond1 has 2
Old Jul 9, 2006 | 10:48 AM
DC2 Mang's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">nothing internally, but the plugs are different, they have the same amount of wires, but the obd2 has one plug and the ond1 has 2</TD></TR></TABLE>
if you can de-pin and re-pin, you can make the obd2 conector fit onto an obd1 car
Old Jul 9, 2006 | 10:51 AM
IVI's Avatar
IVI
Default Re: (DC2 Mang)
anyone have pics of the connectors?
Old Jul 9, 2006 | 10:53 AM
projectTeG's Avatar
not at this moment, but i know it works because im running a 99 civic si distributor on my obd1 gsr swap in my Da
Old Jul 9, 2006 | 10:59 AM
IVI's Avatar
IVI
what kind is this?
the wiring harness is obd2, and the ecu is a p73 jdm itr obd2 ecu.
Old Jul 9, 2006 | 11:06 AM
projectTeG's Avatar
thats obd1
this is obd2
Old Jul 9, 2006 | 11:12 AM
IVI's Avatar
IVI
thank you sir.
also where would i find the casting number?
i seen a couple of obd1 distributors on ebay, whats your opinion?
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jul 9, 2006 | 12:23 PM
lVlemphizStylez's Avatar
Default Re: (IVI)
http://img235.imageshack.us/my...g.jpg
bookmark (if link doesnt work anymore...pm me i have the image)
Old Jul 9, 2006 | 12:27 PM
projectTeG's Avatar
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">http://img235.imageshack.us/my...g.jpg
bookmark (if link doesnt work anymore...pm me i have the image)</TD></TR></TABLE>
***EDIT***
NVM
Modified by projectTeG at 9:51 PM 7/9/2006
Old Jul 9, 2006 | 12:29 PM
strange...i used that image to wire my obd1 JDM dizzy to my obd2 plug...(b series) and it worked just fine
Old Jul 9, 2006 | 12:50 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">strange...i used that image to wire my obd1 JDM dizzy to my obd2 plug...(b series) and it worked just fine</TD></TR></TABLE>
lol, well maybe i did it like that too...
Old Jul 9, 2006 | 01:06 PM
IVI's Avatar
IVI
will that distributor from ebay work for me ? any suggestions or comments about that one?
Old Jul 9, 2006 | 02:26 PM
projectTeG's Avatar
iuno, it might. ive never had to replace my dist. before all i do is replace the internal components
Old Jul 9, 2006 | 02:32 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">iuno, it might. ive never had to replace my dist. before all i do is replace the internal components</TD></TR></TABLE>
i figure it might be easier/cheaper to get that distributor instead of replacing the coil, ignitor, cap and rotor.
Old Jul 9, 2006 | 02:37 PM
Default Re: (IVI)
what exactly is wrong with your distributor
Old Jul 9, 2006 | 02:45 PM
IVI's Avatar
IVI
coil and icm, rotor is stuck the only way i can take it off is to break it, and the cap is old has a crack where the bolt goes.
figure id just buy a whole new distributor and swap it out.
Old Jul 10, 2006 | 01:20 PM
projectTeG's Avatar
Default Re: (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">coil and icm, rotor is stuck the only way i can take it off is to break it, and the cap is old has a crack where the bolt goes.
figure id just buy a whole new distributor and swap it out.</TD></TR></TABLE>
just be carefull and you can pry the cap rotor button off
ham
11
Dec 24, 2006 10:14 AM
3k9civic
Jan 10, 2006 04:25 PM
speedrcr24
Feb 27, 2005 07:16 PM
