DOHC not kicking in...?
Old Jul 8, 2006 | 08:47 PM
EK9KiNG's Avatar
Default DOHC not kicking in...?
i have a 00' Si and my check engine light came on so i took it to autozone and they told me it was cause of my CAI filter needed to be cleaned so i cleaned it and i still have the check engine light and this problem....when i got to redline it will only let me rev up to 6 rpms and both cams dont kick in like supposed to , this started happening like a week ago but i have no idea what it could be ....HELP!!!!
Old Jul 8, 2006 | 08:49 PM
SavEM1's Avatar
did you check your oil?
Did you jump the ecu?
Old Jul 8, 2006 | 09:00 PM
TwoKSiR's Avatar
Default Re: DOHC not kicking in...? (EK9KiNG)
OK bud, for started I could care lass but people are gonna flame you if you say your DOHC doesnt kick in. What you mean is your VTEC isnt kicking in. ANd a airfilter would have to me literally dipped in mub to cause a check engine light.
Second, dont listen to autozone (only had bad luck and alot of laughs, no offence anyone). Follow these instructions http://www.c-speedracing.com/faq/06.php and het back to me as to what the code is and I'll tell you what the problem is. Goodluck.
Old Jul 8, 2006 | 09:06 PM
-JSpecEk*9-'s Avatar
Default Re: DOHC not kicking in...? (TwoKSiR)
haha dohc wont kick in ......lmao
oh and ur not the ek9king im more king than you when it comes to ek9's
Old Jul 8, 2006 | 09:19 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9KiNG &raquo;</TD></TR><TR><TD CLASS="quote">i have a 00' Si and my check engine light came on so i took it to autozone and they told me it was cause of my CAI filter needed to be cleaned so i cleaned it and i still have the check engine light and this problem....when i got to redline it will only let me rev up to 6 rpms and both cams dont kick in like supposed to , this started happening like a week ago but i have no idea what it could be ....HELP!!!!</TD></TR></TABLE>
1.) did Autozone tell you what the code was?
2.) DOHC doesn't "kick in" sweetheart: the cams control different halves of the combustion process and they're both always in motion and they're both always working.
3.) you aren't "redlining" at 6.000rpm, you're hitting a rev limiter of some sort.
Answer: find out what code it is so we can tell you how to fix it.
Old Jul 8, 2006 | 09:26 PM
TwoKSiR's Avatar
Now that I think about i, a while back I got this code on my old B216a2, It was my vtec oil switch. Its a real easy part to swap out if thats it. Takes about 2 minutes literally. Im not saying for sure thats what it is but here is a pic to help.
Just used the pic of example.
The little green plug (in the pic it looks like its under the distributer but its next to it, thats the vtec solenoid. there are 2 plugs on it. the green one on the bottom of the vtec solenoid. thats what i had to replace, you don't need to remove the vtec solenoid to replace that.
Old Jul 8, 2006 | 09:49 PM
DireFire34's Avatar
Default Re: DOHC not kicking in...? (JDMEK-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 &raquo;</TD></TR><TR><TD CLASS="quote">haha dohc wont kick in ......lmao
oh and ur not the ek9king im more king than you when it comes to ek9's</TD></TR></TABLE>
crap! i wonder what would happen if my cam didnt kick in on my SOHC
Old Jul 9, 2006 | 12:55 AM
EGhatch33's Avatar
Default Re: DOHC not kicking in...? (DireFire34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DireFire34 &raquo;</TD></TR><TR><TD CLASS="quote">
crap! i wonder what would happen if my cam didnt kick in on my SOHC </TD></TR></TABLE>
for real! us sohc's would be done for
Old Jul 9, 2006 | 04:37 AM
thahuhstunna's Avatar
Default Re: DOHC not kicking in...? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">1.) did Autozone tell you what the code was?
Answer: find out what code it is so we can tell you how to fix it.</TD></TR></TABLE>
CEL always a good place to start
Old Jul 9, 2006 | 09:18 AM
Default Re: DOHC not kicking in...? (EGhatch33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatch33 &raquo;</TD></TR><TR><TD CLASS="quote">
for real! us sohc's would be done for </TD></TR></TABLE>
my sohc jus toke a **** does that mean my cam didnt kick in?
Old Jul 9, 2006 | 09:26 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9KiNG &raquo;</TD></TR><TR><TD CLASS="quote">i have a 00' Si and my check engine light came on</TD></TR></TABLE>
Find out which ECU trouble code is accompanying the Check Engine Light. How-to:
https://honda-tech.com/zerothread/1171263
Or find out from AutoZone what the code was.
BTW, I would normally make fun of you for confusing "DOHC" with "VTEC," but I'm not really in the mood so I will spare you.
Old Jul 9, 2006 | 10:42 AM
dc2vu's Avatar
oil pressure switch will cause that lower rev limit and vtec to not work...get it wired up and see if youre throwing any more codes
Old Jul 9, 2006 | 12:40 PM
TwoKSiR's Avatar
Come on guys, leave him alone.
Old Jul 9, 2006 | 12:52 PM
CASTUDILLO01's Avatar
DUDE YOUR DOHC ALWAYS KICKS IN? DOHC MEANS DUAL OVER HEAD CAMS ,YOU HAVE TWO CAMS INSTEAD ON ONE. IF YOU MEAN YOUR V-TEC IS NOT KICKING IN CHECK YOUR OIL AND WIRING.
Old Jul 9, 2006 | 01:15 PM
josh200536's Avatar
Default Re: DOHC not kicking in...? (CASTUDILLO01)
It was a question. There's really no reason to be complete ******** because he doesn't know what he's talking about. If you can't help then don't ****** post anything. No reason to be dicks... It's pretty sad that you can't even ask a question without getting your *** ripped or "flamed". This is a place to help other people with problems. This place is pathetic anymore...
Old Jul 9, 2006 | 01:37 PM
dc2vu's Avatar
umm like i said...oil pressure switch
Old Jul 9, 2006 | 02:49 PM
TwoKSiR's Avatar
Default Re: DOHC not kicking in...? (josh200536)
People wonder why people stop coming here. All honda tech is good for is getting flamed by ********, isn't this where people who dont know how to do something get help?
Old Jul 9, 2006 | 03:03 PM
EGhatch33's Avatar
sry i was just jkin, not tryin to flame just have some light fun. my bad.
Old Jul 9, 2006 | 03:07 PM
JRizEJ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASTUDILLO01 &raquo;</TD></TR><TR><TD CLASS="quote">DUDE YOUR DOHC ALWAYS KICKS IN? DOHC MEANS DUAL OVER HEAD CAMS ,YOU HAVE TWO CAMS INSTEAD ON ONE. IF YOU MEAN YOUR V-TEC IS NOT KICKING IN CHECK YOUR OIL AND WIRING.</TD></TR></TABLE>
no need to yell at him. and fyi its vtec.
Old Jul 9, 2006 | 04:01 PM
miffs's Avatar
just my input but those little paperclip tricks don't work.
its a 2000 si right. OBDII b motor then. listen man you have a DLC connector under the dash located by the fuse box. goto honda and have them hook up a scan tool to the connector and they can read all the codes you have that have been eluminated by the MIL (malfunction indicator lamp) and then you can start fixing your car with correct information.
Old Jul 9, 2006 | 04:04 PM
Default Re: DOHC not kicking in...? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, I would normally make fun of you for confusing "DOHC" with "VTEC," but I'm not really in the mood so I will spare you.</TD></TR></TABLE>
thats the same **** everyone has told him to do.^^^^^ look at the links
Old Jul 9, 2006 | 04:08 PM
sicones's Avatar
Default Re: DOHC not kicking in...? (miffs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miffs &raquo;</TD></TR><TR><TD CLASS="quote">just my input but those little paperclip tricks don't work.
its a 2000 si right. OBDII b motor then. listen man you have a DLC connector under the dash located by the fuse box. goto honda and have them hook up a scan tool to the connector and they can read all the codes you have that have been eluminated by the MIL (malfunction indicator lamp) and then you can start fixing your car with correct information.</TD></TR></TABLE>
^^^misinformation, warning: listing to him and 90% of honda-tech will cause lost of brain cells
Eg_hatch_95
Mar 15, 2009 10:35 PM
em1mata
Dec 23, 2007 11:52 PM
badasssi
Jan 20, 2003 10:30 PM
Revgasm
Nov 3, 2002 03:31 PM
Veil_Side_
Oct 9, 2001 06:26 AM
