battery light
Old Jul 8, 2006 | 06:26 PM
SOHC_me's Avatar
Default battery light
my battery light is on when i drive the car, this means it is no longer charging right?, how do i fix this? I bought a new battery and put it it, but the llight is still on. please help
Modified by SOHC_me at 7:43 PM 7/8/2006
Old Jul 8, 2006 | 07:56 PM
SOHC_me's Avatar
Default Re: battery light (SOHC_me)
would maybe a new altornator fix this? Any help please?
Old Jul 8, 2006 | 08:09 PM
BlueIntegraBoy's Avatar
The light is for your charging system. Anything that could go wrong with your charging system can make it go off. Check the belt for your alternator. A new alternator may or may not fix the problem depending on what is wrong.
Old Jul 8, 2006 | 08:14 PM
Slamaccord's Avatar
Default Re: battery light (BlueIntegraBoy)
9 out of 10 times that means its your alternator.
To make sure it not anything else I usually check the B+ wire for 12V using
a test light. If you have 12v to you alternator you now know that their is no break in
the wire between the battery and alternator.
Do you have a check engine light. I believe a code 20 may also cause this
light don't quote me on this though. Its your ELD that most likely has gone bad.
Old Jul 9, 2006 | 01:03 AM
SOHC_me's Avatar
Default Re: battery light (Slamaccord)
whats an ELD?
Old Jul 9, 2006 | 07:18 AM
nocturnaldragon's Avatar
You can take it to autozone for a free electrical test, that way you'll know with 99% certainty what the problem is.
Old Jul 9, 2006 | 07:29 AM
Slamaccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_me &raquo;</TD></TR><TR><TD CLASS="quote">whats an ELD?</TD></TR></TABLE>
Electrical Load Detector.
Old Jul 9, 2006 | 09:56 AM
SOHC_me's Avatar
Default Re: battery light (nocturnaldragon)
I think i'll try taking it to autozone since its free, thanks guys, im prettty sure its the altonator too but well see. Thanks again.
Old Jul 9, 2006 | 10:05 AM
JDM-EJ1's Avatar
I never knew what would cause that light to come on, and now I do.
Old Jul 9, 2006 | 03:23 PM
ManikOne's Avatar
Default Re: battery light (JDM-EJ1)
check all of you major ground cables too. I had this problem a few weeks ago, and found out that the ground cable connected to the tranny loosened when i replaced some motor mounts, tightened and cleaned it, problem fixed.
Old Jul 9, 2006 | 10:40 PM
SOHC_me's Avatar
Default Re: battery light (ManikOne)
so, I think my altonator is bad, bc if i turn the car on the altonator will turn on and the belt will be turning, but when the battery light turns on(which it ushaly turns on when i'm driving 70% of the time) the altonator belt dosent run ot turn. So this means the altonator is not running and my battery is not getting charged, right?
Old Jul 9, 2006 | 11:59 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_me &raquo;</TD></TR><TR><TD CLASS="quote">so, I think my altonator is bad, bc if i turn the car on the altonator will turn on and the belt will be turning, but when the battery light turns on(which it ushaly turns on when i'm driving 70% of the time) the altonator belt dosent run ot turn. So this means the altonator is not running and my battery is not getting charged, right? </TD></TR></TABLE>
More or less.
Old Jul 10, 2006 | 12:20 AM
Ls_V_TurboSi's Avatar
Default Re: battery light (SovXietday)
turn your car on unplug your battery.. If you car dies alternator is dead..
I think your alternator is on its way out... Just go to autozone and they should be abel to tell you whats wrong
Old Jul 10, 2006 | 12:45 AM
B7AudiA4's Avatar
Default Re: battery light (Ls_V_TurboSi)
lately, i've been reading problems, and Vatozone gives more free things than I thought lol.
but I'm pretty sure it's usually the alternator.
It's worth a shot
88hondaspeed
Jun 14, 2011 09:34 AM
Bc1r6x
Jul 18, 2006 04:58 PM
iridebiketrials
Feb 16, 2004 03:01 PM
fe519
Sep 23, 2003 03:25 AM
