bad dizzy bearing
Old Jul 8, 2006 | 02:37 PM
zccr-xsi's Avatar
Default bad dizzy bearing
hey guys i got a weird rattling sound coming from dizzy.i check and evrything inside it good and tight.my question is what does a bad dizzy bearing sound like?the car starts and runs just like it should.its showing no cels.i seen a write-up on how to change it.if anyone has that linked saved could ya post it up.
Old Jul 8, 2006 | 03:02 PM
shortyz21's Avatar
Default Re: bad dizzy bearing (vteckillenzc)
mine squeeled like a bitch.
i bought a used one for 50$
Old Jul 8, 2006 | 04:20 PM
Crx Jimmy's Avatar
grab the rotor and try to wiggle it, if you can wiggle it a couple mm's its bad, it usually makes a grinding screeching noise when going bad
Old Jul 8, 2006 | 04:54 PM
eda6's Avatar
Default Re: bad dizzy bearing (Crx Jimmy)
mine sounded like marbles grinding. The housing was too hot to touch and i also had red dust in my cap. remove it and try to spin the shaft.
Old Jul 8, 2006 | 07:00 PM
zccr-xsi's Avatar
some times it sounds like its also coming from cam gears but there tight? it does it till it warms up then it goes away.put ill try that wiggling the rotor in the morning to see what happens. oh btw this isnt the normal zc valvetrain (tap) or (ticking)
Lasty K
May 5, 2018 02:32 PM
b.d.racing
Mar 4, 2008 04:44 PM
bleedblue94
Jan 7, 2006 10:08 PM
boostinb20vtec
Apr 22, 2004 04:32 PM
0ptimus prime
Apr 13, 2004 07:51 AM
