TRANSMISSION QUESTION...NEED HELP ASAP!!!!!!
Old Jul 7, 2006 | 09:39 PM
greddy13's Avatar
Default TRANSMISSION QUESTION...NEED HELP ASAP!!!!!!
ok so i just bought a stg 1 competition clutch. it came with the clutch, clutch plate, bearing, and this round pieace you put on the tranny. so i put it in the round pieace, and when you push the clutch lever down it pops out and when u let it out it goes back in, so im puttin in my tranny and it pops out, and i pushed the lever down and it stayed out. my question is when the tranny is connected will it go back to normal?
Old Jul 7, 2006 | 09:40 PM
greddy13's Avatar
Default Re: TRANSMISSION QUESTION...NEED HELP ASAP!!!!!! (greddy13)
will the clutch work? b/c when the tranny was out, the round thing stayed poped out even if you pushed the lever
Old Jul 7, 2006 | 11:15 PM
greddy13's Avatar
????i need to no asap...
Old Jul 8, 2006 | 05:00 AM
-Kirk-'s Avatar
It's called the clutch release bearing(throw out bearing). Make sure the 2 ears on the back of it are locked on the arm good. If it's installed properly it shouldn't fall off.
Old Jul 8, 2006 | 06:34 AM
postman's Avatar
need more detail on the round piece. cuz you mentioned a bearing and a round piece. assuming the bearing is the release bearing. dont know what the round thing could be
Old Jul 8, 2006 | 06:35 AM
greddy13's Avatar
Default Re: TRANSMISSION QUESTION...NEED HELP ASAP!!!!!! (postman)
ok then i guess its called the release bearing, its hooked onto the trannsmission good, jus its poped out and when i push the lever down it stays out.
crazykamper
Jul 22, 2008 12:51 PM
2.0L Beater
Oct 20, 2007 03:47 PM
DJ Gurgla GSR
Jul 21, 2006 05:57 AM
greddy13
Jul 9, 2006 01:53 PM
AzntaggeR
Feb 18, 2003 06:01 PM
