b16a oil pump?
Old Jul 7, 2006 | 09:18 PM
killerB16A's Avatar
Default b16a oil pump?
i have a 92-95 b16a what years oil pumps cam i use? can i use any b-series oil pump?
Old Jul 8, 2006 | 06:21 PM
hondapwr's Avatar
Default Re: b16a oil pump? (killerB16A)
Try em out and see what fits. Just make sure the place you buy from has a good return policy.
If I remember correctly, the OBD level of the engine may affect which part you need.
Old Jul 8, 2006 | 06:28 PM
pdiggitydogg's Avatar
Any obd2 oil pump will work fine for the b16a (even an LS pump is the same)
The only difference you may find, is that the fit of the lower timing cover over certain pumps - obd2 pumps require more room than obd1 (ls pump anyways) so some trimming is required.
If youre really just paranoid about it, get a pump for the 94-00 b16a2/3. Then compare that part number to that of any other obd2 oil pump, and you'll see its the same.
Old Jul 8, 2006 | 06:55 PM
prjctwhteg's Avatar
Default Re: (pdiggitydogg)
just buy a spoon oil pump and be done with it
Old Jul 8, 2006 | 07:15 PM
ridiculous advice
spoon...pfft
Old Jul 8, 2006 | 08:30 PM
doublejz's Avatar
screw spoon oil pumps... had many builds and oem is fine.. to answer your question i usually use 94-97 del sol vtec oil pumps for my b16 builds
Old Jul 9, 2006 | 09:28 AM
killerB16A's Avatar
Default Re: (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">screw spoon oil pumps... had many builds and oem is fine.. to answer your question i usually use 94-97 del sol vtec oil pumps for my b16 builds</TD></TR></TABLE>
this is what honda is telling me to do. i did not know that the put a b16 in them? i thought they where saying d16. so i shall use the del sol pump....thanx for the help
Old Jul 9, 2006 | 04:13 PM
doublejz's Avatar
Default Re: (killerB16A)
umm yea if its just a stock 92-95 civic i doubt you have a bseries in there
B16A 1992-1995 Civic SiR II (JDM) /Del Sol
B16A3 1994-1995 Del Sol
D16Z6 1992-1995 Civic EX/Si/Del Sol Si
D15B7 1992-1995 Civic DX/LX
D15B8 1992-1995 Civic CX
D15Z1 1992-1995 Civic VX
Old Jul 9, 2006 | 06:37 PM
d16vtecx's Avatar
USDM obd2 oil pumps have a sensor on them so unless you want unconnected plugs hanging get an obd1 or obd0 pump
Old Jul 9, 2006 | 10:39 PM
killerB16A's Avatar
Default Re: (d16vtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">umm yea if its just a stock 92-95 civic i doubt you have a bseries in there </TD></TR></TABLE>
did you see that it said b16a........um i think that would be jdm
Old Jul 9, 2006 | 11:43 PM
sinister6's Avatar
For my B18CR overhaul i swap in a toda oil pump gear. just to be save.(let say its a 10 years old block)
Old Jul 10, 2006 | 11:09 AM
doublejz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">
did you see that it said b16a........um i think that would be jdm </TD></TR></TABLE>
yea yea
Old Jul 10, 2006 | 11:28 AM
SkoundrelUSA's Avatar
cute little bastard
this is what honda is telling me to do. i did not know that the put a b16 in them? i thought they where saying d16. so i shall use the del sol pump....thanx for the help </TD></TR></TABLE>
Make sure its from the DEL SOL VTEC and not the Si (that had a Z6 in it)
Old Jul 10, 2006 | 12:57 PM
egsleepercivic's Avatar
94-95 Del Sol Dohc vtec (b16a3)
Old Jul 11, 2006 | 12:14 AM
killerB16A's Avatar
Default Re: (egsleepercivic)
well i have the old one out so i will take it with me to double check it.
JMd16z6T
Jun 12, 2015 04:36 AM
stockbee
Jan 2, 2008 08:32 PM
Sassafrass
Jul 21, 2005 08:02 AM
TeggerLS
Feb 22, 2002 08:36 AM
