b16a oil pump?
Re: b16a oil pump? (killerB16A)
Try em out and see what fits. Just make sure the place you buy from has a good return policy.
If I remember correctly, the OBD level of the engine may affect which part you need.
Any obd2 oil pump will work fine for the b16a (even an LS pump is the same)
The only difference you may find, is that the fit of the lower timing cover over certain pumps - obd2 pumps require more room than obd1 (ls pump anyways) so some trimming is required.
If youre really just paranoid about it, get a pump for the 94-00 b16a2/3. Then compare that part number to that of any other obd2 oil pump, and you'll see its the same.
Re: (pdiggitydogg)
screw spoon oil pumps... had many builds and oem is fine.. to answer your question i usually use 94-97 del sol vtec oil pumps for my b16 builds
Re: (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz »</TD></TR><TR><TD CLASS="quote">screw spoon oil pumps... had many builds and oem is fine.. to answer your question i usually use 94-97 del sol vtec oil pumps for my b16 builds</TD></TR></TABLE>
this is what honda is telling me to do. i did not know that the put a b16 in them? i thought they where saying d16. so i shall use the del sol pump....thanx for the help
Re: (killerB16A)
umm yea if its just a stock 92-95 civic i doubt you have a bseries in there
B16A 1992-1995 Civic SiR II (JDM) /Del Sol
B16A3 1994-1995 Del Sol
D16Z6 1992-1995 Civic EX/Si/Del Sol Si
D15B7 1992-1995 Civic DX/LX
D15B8 1992-1995 Civic CX
D15Z1 1992-1995 Civic VX
Re: (d16vtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz »</TD></TR><TR><TD CLASS="quote">umm yea if its just a stock 92-95 civic i doubt you have a bseries in there </TD></TR></TABLE>
did you see that it said b16a........um i think that would be jdm
Re: (doublejz)
For my B18CR overhaul i swap in a toda oil pump gear. just to be save.(let say its a 10 years old block)
Re: (killerB16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A »</TD></TR><TR><TD CLASS="quote">
did you see that it said b16a........um i think that would be jdm </TD></TR></TABLE>
yea yea
yea yea
cute little bastard
Re: (killerB16A)
this is what honda is telling me to do. i did not know that the put a b16 in them? i thought they where saying d16. so i shall use the del sol pump....thanx for the help </TD></TR></TABLE>
Make sure its from the DEL SOL VTEC and not the Si (that had a Z6 in it)
