how to install civic radiator in integra????
Old Jul 7, 2006 | 05:37 PM
Orangecivic251's Avatar
Default how to install civic radiator in integra????
i know there was a thread on it and i can't find it searching for slammeddc2 who needs the info asap thanks guys
Old Jul 7, 2006 | 05:40 PM
G2 Speed's Avatar
Default Re: how to install civic radiator in integra???? (OrangeCiviC251)
full edit: need more info!!
https://honda-tech.com/zerothread?id=1587638?!?!
Old Jul 7, 2006 | 05:45 PM
egcivicdelsol's Avatar
Default Re: how to install civic radiator in integra???? (G2 Speed)
if you would like to do it the correct way... like i put a type r radiator, for my type r motor, in my eg2 chassis... i drilled out the old brackets the radiator sat on.... u just get a drill... and drill through where the circles are on each bracket... you'll see them... and then get a shop to weld them in the correct spot where it should sit... and then there you go.
Old Jul 7, 2006 | 05:47 PM
G2 Speed's Avatar
Default Re: how to install civic radiator in integra???? (egcivicdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicdelsol &raquo;</TD></TR><TR><TD CLASS="quote">if you would like to do it the correct way... like i put a type r radiator, for my type r motor, in my eg2 chassis... i drilled out the old brackets the radiator sat on.... u just get a drill... and drill through where the circles are on each bracket... you'll see them... and then get a shop to weld them in the correct spot where it should sit... and then there you go. </TD></TR></TABLE>
dude you read wrong
it's the other way civic radiator in integra
Old Jul 7, 2006 | 05:51 PM
ohhh... oops. wtf would u want to do that anyway??? if so read my thread vise versa.
Old Jul 7, 2006 | 05:53 PM
so... drill out your integra mounts... same way i explained above... drill holes through the spot welds... then break them off or wedge them off... and then get someone to weld them in the correct spots and BAM good to go... game over.
Old Jul 7, 2006 | 05:54 PM
he wants to do it to run a rmf header
Old Jul 7, 2006 | 06:10 PM
baozer's Avatar
bump
Old Jul 7, 2006 | 06:49 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicdelsol &raquo;</TD></TR><TR><TD CLASS="quote">ohhh... oops. wtf would u want to do that anyway??? if so read my thread vise versa. </TD></TR></TABLE>
hahahah
Old Jul 7, 2006 | 07:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
hahahah</TD></TR></TABLE>
its true. its true.
jumbronee
Nov 23, 2008 09:10 PM
Flipnotize21
Honda Civic (2006 - 2015)
Nov 6, 2006 12:16 PM
JDM turbo DC
Mar 1, 2006 12:41 PM
SilverGSR99
Jun 21, 2004 09:19 PM
confucius
Nov 2, 2001 04:29 PM
