how to install civic radiator in integra????
i know there was a thread on it and i can't find it searching for slammeddc2 who needs the info asap thanks guys
Re: how to install civic radiator in integra???? (G2 Speed)
if you would like to do it the correct way... like i put a type r radiator, for my type r motor, in my eg2 chassis... i drilled out the old brackets the radiator sat on.... u just get a drill... and drill through where the circles are on each bracket... you'll see them... and then get a shop to weld them in the correct spot where it should sit... and then there you go.
Re: how to install civic radiator in integra???? (egcivicdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicdelsol »</TD></TR><TR><TD CLASS="quote">if you would like to do it the correct way... like i put a type r radiator, for my type r motor, in my eg2 chassis... i drilled out the old brackets the radiator sat on.... u just get a drill... and drill through where the circles are on each bracket... you'll see them... and then get a shop to weld them in the correct spot where it should sit... and then there you go. </TD></TR></TABLE>
dude you read wrong
it's the other way civic radiator in integra
dude you read wrong
so... drill out your integra mounts... same way i explained above... drill holes through the spot welds... then break them off or wedge them off... and then get someone to weld them in the correct spots and BAM good to go... game over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicdelsol »</TD></TR><TR><TD CLASS="quote">ohhh... oops. wtf would u want to do that anyway??? if so read my thread vise versa. </TD></TR></TABLE>
hahahah
hahahah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">
hahahah</TD></TR></TABLE>
its true. its true.
its true. its true.
JDM turbo DC
03-01-2006 12:41 PM
