Dual bend quick question.
I just installed my B&M dual bend and think I put it in backwards. The lower bend bends toward me and the upper bend goes straight up. I was sure that was right, but now when it is in first gear the top of the **** points away from me, and when it is in third gear it point straight up. In neutral it points slightly forward. It seems like it should be reversed, anyone know?
./ Driver
| Poor depiction(sp) but it helps
./ Driver
Well the first bend bends toward the rear then it bends back up. For some reason its still pointing forward. I guess im just going to reverse it. The rubber o-rings that are supose to be some poor attempt at a washer are crap IDK WTF B&M was thinking on that one. Im going to custom make some rubber or silicone ones so might as well reverse it while im at it.
You can only put it on two ways ..
./ <-- that end goes towards the back of the car
.\ <-- if you put it like that, with the bend going towards the front, it would be Way off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg »</TD></TR><TR><TD CLASS="quote">You can only put it on two ways ..
..|</TD></TR></TABLE>
Right... I have it the top way but its pointing foward most all of the gears.
Cashieboi
Jan 30, 2007 03:51 PM
Rod.
Aug 9, 2004 10:28 AM
