Just changed clutch in a 90 crx, now i can't get the car in gear when i turn it on.
As stated above.
When the car is off i shift gears fine. (too bad that's not when it counts)
Could the problem be that i might have gotten my flywheel mixed up with that of my 89 hatch?
Is the clutch cable adjusted properly? Is it pulling enough on the shift arm? Did you replace the fluid in the tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">Is the clutch cable adjusted properly? Is it pulling enough on the shift arm? Did you replace the fluid in the tranny? </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">First thing to do is make surethe clutch cable is pulling the arm up as much as is easly doable by hand. </TD></TR></TABLE>
The reason he can't get it in gear is because the cable is too loose and he's trying to shove it in gear without actually putting the clutch in. I have had this problem, I do not think it's possible to overtighten the clutch cable.
jondancer
Jun 9, 2003 02:57 AM
