Old Jul 7, 2006 | 10:04 AM
CRXCIVICMIX's Avatar
Default ????
What is IAC?
Old Jul 7, 2006 | 10:09 AM
SVOboy's Avatar
The IACV/EACV is the idle/electronic air control valve which decides how much air goes in to the engine at idle to keep the idle steady.
Old Jul 7, 2006 | 10:11 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">The IACV/EACV is the idle/electronic air control valve which decides how much air goes in to the engine at idle to keep the idle steady. </TD></TR></TABLE>
You are correct
where is it and how can i check it
Old Jul 7, 2006 | 10:14 AM
SVOboy's Avatar
On theback of the IM, a plug with two wires and two coolanthoses, held on by two 12mm bolts. Take it off and spray some fuel injection cleaner in it to get all the **** out.
Old Jul 7, 2006 | 10:36 AM
ludesrv's Avatar
If you have MPFI.
I'm not sure if DPFI has it, but it's in a different location if it does. I know NOTHING about DPFI other then it sucks.
Old Jul 7, 2006 | 10:39 AM
SVOboy's Avatar
DPFI has it, it's somewhere, looks about the same.
Old Jul 7, 2006 | 12:04 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">DPFI has it, it's somewhere, looks about the same.</TD></TR></TABLE>
Yes, it is on the driver side upper intake manifold. It is on the closest runner to the brake MC. it has 2/3 hoses and 2 bolts.
`chrisb
May 4, 2008 01:46 PM
Junkyard2000
Oct 26, 2005 03:16 PM
RACEPAK
Nov 28, 2004 12:58 PM
b16acrxer
Aug 31, 2004 09:02 AM
2k1_ITR_0736
Jun 18, 2003 11:53 AM
