Sorta OT: Quick fix to slippery pedals
Old Apr 19, 2002 | 10:49 AM
Casey's Avatar
Default Sorta OT: Quick fix to slippery pedals
Well Im not sure if this has been posted before, but I have aluminum pedals on my car, and like most aluminum pedals they get slick when wet. I know you want the gas to be smooth for good throttle control but you sure as hell dont want your foot to slip off the clutch or brake, so what i did was buy some stick-on sandpaper designed for a sanding block(the sandpaper has an adhesive back). All i did was take a couple sheets and cut them down to the size i needed, apply to the brake and clutch, and there you have it, a simple solution to slippery pedals they may not be mugen but they are less expensive and do the same job
Old Apr 19, 2002 | 10:52 AM
Type Goch's Avatar
New User
Default Re: Sorta OT: Quick fix to slippery pedals (TypeRformewhenIB18)
Try using some skateboard griptape, probably the same thing as the sandpaper you're refferring to.
Old Apr 19, 2002 | 10:55 AM
AssPenny's Avatar
Default Re: Sorta OT: Quick fix to slippery pedals (Type Goch)
Yup grip tape works good. Just cut a square bigger then the pedal, stick it to the pedal and run a razor blade along the edge and its a perfect cut every time You can also rub a file (or screw driver) along the edge of the pedal a few times and that will cut the tape also.
Craig - Who is a pro at grip taping a skate board from working at a surf/skate shop.
muddmonky
10
Jan 11, 2013 08:49 AM
AzCivic1.6
Oct 21, 2005 09:48 PM
tweekerz
Jul 28, 2005 08:57 AM
ion_four
30
Jul 25, 2003 08:47 AM
EleanoR
Sep 17, 2002 05:27 AM
