helpppppp!! oil leak
Old Jul 6, 2006 | 11:34 PM
fackyou's Avatar
Default helpppppp!! oil leak
ok so i go out to my car and take out the garage to move it. When I go back in there is like small puddles of oil. I'm like ok, i didnt pay no attention because im like it can't be from my car. So i cleaned it up, and put my car back in the garage. I took it out the next day came back and there it was again. So im like expletive. I don't know where im leaking oil from. Anyone know any possible areas to check. Right now i think it's maybe from my oil pan, still not sure. Any help appreciated thanks
Old Jul 6, 2006 | 11:45 PM
Dartanian's Avatar
Default Re: helpppppp!! oil leak (jdmitr03)
Definitely check the oil pan. An old gasket may be causing the leak.
Also, the oil pressure sensor located left of the oil filter may be leaking. Check that and if it is, apply some teflon tape to its threads and put it back in.
Old Jul 7, 2006 | 12:14 AM
98IntegraLSNonVtec's Avatar
Default Re: helpppppp!! oil leak (Sleeper Style)
^^^And clean the underside of your car..where you see the oil leak and drive it for about 5-10 minutes come back go under your car and try to see where exactly the leak is coming from.
Old Jul 7, 2006 | 12:24 AM
fackyou's Avatar
Default Re: helpppppp!! oil leak (98IntegraLSNonVtec)
alrighty i'l check on that this weekend.... thanks guys
PunchedGuava
28
Sep 8, 2013 11:23 AM
lanojp1
Sep 2, 2004 04:00 PM
hondaracing1
Aug 19, 2004 05:16 PM
Civic_Type R
15
Sep 28, 2003 06:44 PM
