Shift light install problem
Old Jul 6, 2006 | 07:51 PM
dizzyek's Avatar
Default Shift light install problem
aight I got my hands ona autometer shift light for cheap and went to hook it up today as follows:
Red wire: hooked up to the power wire on my stereo
Black: Grounded it to a ground in the engine bay
Green wire: connected it to the blue wire on the drivers side shock tower
When I turn the the car on the light goes on for about four seconds then goes off
The light does not turn on when it suppose to. The catridge that came with it is set at 6800 rpm.
could the cartridge be bad????
Old Jul 6, 2006 | 08:07 PM
BauleyCivic's Avatar
Risky Business
Default Re: Shift light install problem (dizzyek)
You realize your stock tach is off, right? 7100RPM on my stock tach is actually 6800 rpm.
Old Jul 6, 2006 | 08:14 PM
hckyNhonda29's Avatar
Default Re: Shift light install problem (BauleyCivic)
Is it at all possible to reset a stock tac? Possibly calibrate it some way?
If it is possible, how?!
Old Jul 6, 2006 | 08:35 PM
dizzyek's Avatar
so my tach is off by 300 rpm or so. I never knew this.
Old Jul 6, 2006 | 09:20 PM
Syndacate's Avatar
Yeah but is that ur problem? What happens if u hit the rev-limiter with it, does it flash?
Old Jul 6, 2006 | 09:32 PM
hatchi's Avatar
make sure the switch on the back of the shiftlite is set to 4cyl
Old Jul 6, 2006 | 09:59 PM
dizzyek's Avatar
its set a 4 cylinders and i have'nt taken it to the revlimiter.
Old Jul 6, 2006 | 10:08 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (dizzyek)
Why did you hook it to your stereo power? You have a fuse box with a very easy-to-access ignition = hot switch in it right below the steering column.
Have you tried a different pill or are you just assuming that the 6800 is in proper working order? Did you read the instructions? Have you called Autometer?
j_kevin_ca
26
Oct 14, 2004 10:13 AM
ShakesTheKlown
Jun 15, 2004 06:59 PM
trutuner
May 25, 2003 06:37 PM
speedymon
Aug 4, 2002 11:41 AM
