CTR pistons in B18C GSR motor with B16 head too high compression?????????
He guys my B16 is burnin oil like crazy so i decided to put together my GSR block just wonderin if I put the CTR pistons in it will my compression ratio be too high???
I am going to port the head out type-r valve sprigns I just want to know if this is a ok bottom end?????and the CTR pistons ok???
I am goin to be runnin CAT CAMS they are alittle bit bigger then the ITR with a crazy idle lobe. SO is this a good set up???? ANd i currently have hondata a sheet metal intake and bored out throtle body and so forth
Yea it'll be cool just like everyone else said. Run 92+ octane and retard the timing, watch for signs of detonation and back down the timing more if needed.
swaytec360
Jan 14, 2005 05:11 PM
EFing8
10
Dec 14, 2002 04:00 PM
