Muffler silencers - Does it really work?
Old Jul 6, 2006 | 06:17 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Muffler silencers - Does it really work?
Example
They are pretty expensive. So I want to make sure I don't waste $$$.
Tell me the good, bad, and ugly. I know nothing. There are those "Universal," so they should be universal, right?
I have a Magnaflow 14815 muffler.
TIA
Old Jul 6, 2006 | 06:27 PM
ekcivic9's Avatar
yes they work, but it makes your muffler look really ugly
Old Jul 6, 2006 | 06:33 PM
D50boy's Avatar
Default Re: Muffler silencers - Does it really work? (GoLowDrew)
I like mine. It came with my RS*R GTII. I only use it for long trips and if I want to have a conversation with whoever I'm driving with.
Old Jul 6, 2006 | 07:14 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Do you guys think if I was to weld a restrictive plate in the inlet of the muffler to cut it down by 1/4 or 1/2 of an inch it would be the same as a silencer? Like a permanet silencer?
The only thing is it's on the inlet, where as the silencer you have is on the outlet.
Old Jul 6, 2006 | 07:21 PM
Sleepy_Red_hatch's Avatar
you might create a whistle
Old Jul 6, 2006 | 08:04 PM
BauleyCivic's Avatar
Risky Business
Default Re: Muffler silencers - Does it really work? (Sleepy_Red_hatch)
They work drew. I'd say my car is probably 40% quieter with one in...of course I don't have any hard numbers but the difference is noticable.
Old Jul 6, 2006 | 08:12 PM
Metalluthier's Avatar
No, because air is only being blocked not controlled and it will then force more air out through a smaller hole making your car sound worse. You have to have a certain amount of air pressure existing inside of your muffler or pipe to silence itself, acting as plain muffler, using sound and pressure to resist itself. All you really need is a petruding pipe and one face shield to control air pressure. Thus it will create a mirror sound wave to cancel out the existing sound
Old Jul 6, 2006 | 08:14 PM
Risky Business
Default Re: Muffler silencers - Does it really work? (Metalluthier)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metalluthier &raquo;</TD></TR><TR><TD CLASS="quote">No, because air is only being blocked not controlled and it will then force more air out through a smaller hole making your car sound worse. You have to have a certain amount of air pressure existing inside of your muffler or pipe to silence itself, acting as plain muffler, using sound and pressure to resist itself. All you really need is a petruding pipe and one face shield to control air pressure. Thus it will create a mirror sound wave to cancel out the existing sound.
Jesus man, you need to get off Honda-Tech and design a car that runs on water vapor.
Good response
Old Jul 6, 2006 | 08:20 PM
Hond@'s Avatar
Default Re: Muffler silencers - Does it really work? (BauleyCivic)
It does sound quieter, but it doesn't good or look good
Old Jul 6, 2006 | 08:21 PM
kiddcarbuff's Avatar
yea its def quieter, my skunk2 is maddd loud w/out it, but when its in its really not bad
Old Jul 6, 2006 | 08:22 PM
GoLowDrew's Avatar
Old Member
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metalluthier &raquo;</TD></TR><TR><TD CLASS="quote">All you really need is a petruding pipe and one face shield to control air pressure. Thus it will create a mirror sound wave to cancel out the existing sound
I understand what you are saying, but I have a hard time imagining the "petruding pipe and one face shield to control air pressure" part.
Please explain.
Old Jul 6, 2006 | 09:02 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Ya it will be quieter, but u will feel some resistance while driving with it on.
Old Jul 6, 2006 | 09:20 PM
GreenEHDriver's Avatar
i wouuld lik 2 buy a Hamdumbger
Old Jul 7, 2006 | 11:14 AM
GoLowDrew's Avatar
Old Member
25 Year Member
The above picture, for example. The silencer has a hole on the rim lip. That is so it's screwed lock it on the muffler. Are all silencers held in my a screw? Or does some use pressure as you push it in?
Old Jul 7, 2006 | 11:45 AM
Risky Business
Theres a screw going through the muffler tip holding the silencer in.
DelSolMarine
Aug 8, 2013 05:34 AM
r1ch
Mar 12, 2009 03:31 PM
bumthology
Apr 3, 2006 08:03 AM
Type Wah
Dec 20, 2005 11:11 AM
LostCRX
Apr 20, 2005 05:34 PM
