help w/intake setting...
Old Jul 6, 2006 | 03:00 PM
The Collin's Avatar
Default help w/intake setting...
ok, the motor is the stock cx motor in a 99 civic hatch, and a while back a friend of mine told me i could adjust that screw behind the throttle body to make it quicker while rolling. well now i've messed with it a few times to get more/less air, got into a wreck and had to redo my whole a/c system and my car bogs with the a/c on, so i'd like to put that screw back to stock position. my question is is there any way to put it back to stock, like how many complete turns from all the way down or up? anyone?
Old Jul 6, 2006 | 03:11 PM
The Collin's Avatar
Default Re: help w/intake setting... (99_hb_on_air)
also, i will be turbo'ing this in mid-august , so i'd like to get this solved by then, although i am puttin on a y8 mani. anywho... input is appreciated regarding the intake control
Old Jul 7, 2006 | 03:56 PM
The Collin's Avatar
nobody @ all?
Old Jul 7, 2006 | 03:59 PM
G2 Speed's Avatar
Default Re: (99_hb_on_air)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_hb_on_air &raquo;</TD></TR><TR><TD CLASS="quote">nobody @ all?</TD></TR></TABLE>
Can't help you, get ahold of a helms manual or something that would be the best bet
schardbody's Avatar
there is no stock setting, factory calibrated for each particular vehicle. keep playing w/ it a little bit each day and eventually you will get it right.
Old Jul 7, 2006 | 06:54 PM
The Collin's Avatar
now i've got it to where it doesn't necessarly bog with a/c on, but it doesn't seem to accelerate like it should guess ill just keep adjusting it. thanks.
Old Jul 7, 2006 | 08:42 PM
swap_killer7079's Avatar
if it helps any i set mine because my car was idling high. it sticks out 1/16 of an inch from the throttle body.
Old Jul 8, 2006 | 01:37 PM
schardbody's Avatar
Default Re: (swap_killer7079)
i wouldnt adjust it out that far.
simonEp3
18
Nov 28, 2007 12:28 PM
BiG_DeE
Nov 25, 2007 07:11 PM
macdaddydelux
Nov 9, 2007 07:23 AM
Pilky
Nov 9, 2006 12:29 PM
ryaninsocal
Dec 17, 2005 06:52 PM
