I need intercooler pipe recommendations
Old Jul 6, 2006 | 10:28 AM
Bird333's Avatar
Default I need intercooler pipe recommendations
I got a '96 LX I want to turbo. I want to keep the PS and AC. It will have a fmic. The compressor outlet will be pointing up toward the hood. The pipe will go toward the washer fluid tank, down behind the bumper to the i/c. I want 2" pipe running from the turbo to the i/c and 2.5" from i/c to throttle body.
How many and what bends do I need of each diameter?
TIA
Old Jul 6, 2006 | 01:07 PM
notoriousB's Avatar
Default Re: I need intercooler pipe recommendations (Bird333)
tough question man. best thing to do is just go mock it up and try to visualize the piping in your mind.
why do you want to have the compressor face up? mine's straight down.
going on MEMORY I have the following: (again, pointing DOWN)
<u>2" pipe</u>
1 x 90*
1 x 180*
<u>2.5" pipe</u>
3 x 90*
and a couple of other bends to get to the throttle body. these are more like 45* not 90/180.
Old Jul 6, 2006 | 01:34 PM
raceACCORDingly's Avatar
2.5" all the way. ive seen a couple setups like this w/ 2.5" that fit the washer fluid tank hole perfectly.
heres another setup but i can hotlink the pic http://denniscraig.org/pics/ac...G.php
Old Jul 6, 2006 | 01:40 PM
CBURKE's Avatar
the place in my sig, you can just order them and cut them your self.
Old Jul 7, 2006 | 06:02 AM
Bird333's Avatar
Default Re: (Mr Wonderfull)
Thanks for the pics. Can you give the specifics on the pipe sizes/angles? I don't plan on using the washer tank hole, I want to keep that. I was wanting to use the hole on the left of this pic where the wire loom runs. http://denniscraig.org/pics/ac...G.php I don't know how possible it is because of where the washer tank is. Do I need any straight pieces?
Also where do you recommend I get the parts and couplers from? Oh, and I plan on using stainless steel or aluminum. I would like to get aluminum, but I am having a hard time finding 2" aluminum.
More opinions guys.
Thanks!
Old Jul 7, 2006 | 10:01 AM
Bird333's Avatar
Thanks for the links. Did you explore routing the hotside piping where I mentioned? Any other areas? If so, what problems/issues did you run into which made you run the hotside like you did? Are your powersteering cooler lines still in the original location?
Old Jul 7, 2006 | 11:33 AM
yeah i originally thought that routing it through the washer fluid hole was a no go with ABS but that pic w/ the ramhorn has all ABS still there.
heres one w/ no ABS
Silentxracer
Texas -OK -LA (Sales)
Jan 10, 2011 05:06 PM
TurboSI56
Welding / Fabrication
Jul 12, 2006 01:01 PM
otto
Aug 31, 2005 07:22 PM
RedTegLS
Oct 14, 2003 04:12 PM
MikeMAN
Feb 25, 2003 07:30 PM
