running rich?
installed test pipe 2 weeks ago and there is smoke coming out my exhaust at high rpms.
after i installed the test pipe thats when the smoke appeared and im not burning oil because my oil level is at same level since i changed it. what color smoke usually tells when your running rich? can someone explain the colors running rich and burning oil please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R »</TD></TR><TR><TD CLASS="quote">Running rich = black, there will be black soot on bumper/exhaust tip
Burning oil = bluish smoke
Burning coolant = white smoke</TD></TR></TABLE>
ok there is black **** stains on my exhaust tip, but not bumper yet. but the smoke is white so im burning coolant? so this means im burning coolent and running rich sametime...jeez.
look at your spark plugs
black=rich
white=lean
bronze/brownish=stoich
oil on the plug= burning oil
you are probably burning a tiny bit oil at high rpms and the cat is not there to burn off the smoke, this is normal, if you lose less that a quart between oil changes that is the standard amout vtec engines burn, Acura wont reccomend service for your car if it is burning that much or less
black=rich
white=lean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang »</TD></TR><TR><TD CLASS="quote">look at your spark plugs
black=rich
white=lean
bronze/brownish=stoich</TD></TR></TABLE>
i changed my sparkplugs to ngk last week, there is no black white or any color stuff on it.
black=rich
white=lean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_violator »</TD></TR><TR><TD CLASS="quote">i must be really new to this when i dont know what running rich means...what does that mean?</TD></TR></TABLE>
there is too much fuel entering the combustion chamber and being burnt
running righ burns out cats, o2 sensors, and can wash out clyinder walls along with causing other misc internal problems
running righ burns out cats, o2 sensors, and can wash out clyinder walls along with causing other misc internal problems</TD></TR></TABLE>
thanx
thanx
My teg was smoking when i had a test pipe on as well. It also has a secondary o2 sensor that was left unhooked when the test pipe was put on. I got a carsound cat on it now and the o2 sensor is hooked back up again and no more smoke.
also burns the eyes =P
GSR_hatch936
21
Apr 28, 2007 11:10 PM
