Knock/Map sensor help
I thought id post this in here b/c im using a p72 ecu ,hoping you guys can help out.
I have a 97 lude with a JDM h22 tuned with basic bolt ons tuned with Hondata s200.I was driving home tonight and it seemed to hit off what felt like a rev limiter at like 6000-6500 rpms,it then was bogging and hesitating really bad and didnt want to accelerate at all it just wanted to stall.Every time is try to start it it would just die like it was starving for gas.I was able to pull Cel 3 which is MAP sensor, but could this be related to knock sensor problems too? Thanks in advance
Well to get it at least running again I'd reset the ecu if you haven't done so yet. On mine if I pull a map cel, the car won't run properly until it's reset. If you hook it up to the OBD reader (name?) like a Snap-On one it'll tell you what the map and knock sensor input readings are and you can find out which is at fault. Most shops will have one, if you've got a friend who works for one have them hook it up.
My guess is your hondata unit is not working properly which is throwing you into a fuel cut....
If you are throwing a code normally, then it is another issue, such as wiring etc.
