Best ram air hood for 5th gen?
Old Jul 5, 2006 | 12:02 PM
HondaPH22's Avatar
Default Best ram air hood for 5th gen?
whats the best hood for the 5th gen as far as cooling purposes?? i have a turbo kit trying to cool down a little bit. spyder 2?? any suggestions here
Old Jul 5, 2006 | 12:05 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Best ram air hood for 5th gen? (HondaPH22)
you are wanting a "ram air" hood? cant you just heat wrap it and things like that? i doubt you will find a "nice looking" ram air hood that really flows with the body lines of the lude would you?
Old Jul 5, 2006 | 01:55 PM
pizzamanprelude's Avatar
Default Re: Best ram air hood for 5th gen? (AnthonyG2003)
you would be better fitting vents in the area below the windscreen, lower air pressure in that area sucks air out of the engine bay and allows cooler air to flow in from underneath and in front.
Old Jul 5, 2006 | 02:55 PM
petern101's Avatar
Default Re: Best ram air hood for 5th gen? (pizzamanprelude)
and/or not worry about it
seems like there are 400 hp preludes and they have oem style cf hood or oem hoods
probably something you really don't need to worry about unless you've done everything else
Old Jul 5, 2006 | 03:27 PM
HxClude's Avatar
Default Re: Best ram air hood for 5th gen? (petern101)
have you coated your turbo exhaust housing, and exhaust manifold with a hi-temp coating? Hipercoat Extreme from HPC and Swain Tech White Lightning are well worth the money to reduce underhood temps. They last a long time and protect the metal rather than cook it like exhaust wrap does.
As far as hoods go, prop yours up a few mm at the windshied end with washers.
Old Jul 5, 2006 | 04:08 PM
A Blue Lude's Avatar
Evo style would probably work.
Old Jul 5, 2006 | 05:38 PM
spliffsta2's Avatar
yea, i agree, i dont think there are any that would look nice with the prelude body... I saw one the other day on a EBP lude and it honestly looked repulsive.
prayludin
May 5, 2006 12:54 PM
HickamHatch
Sep 24, 2005 12:41 AM
vtec.dc2
May 8, 2004 05:22 AM
WhitEdRift
Apr 15, 2003 11:46 AM
creasian
Sep 11, 2002 10:12 AM
