Update on my LS/Vtec setup
This Build has basically been built by a lot of members on this site. I just thought that I would post up a couple of pics.
Here is the Setup:
B18A1 Block:
B16A2 Pistons
GSR Water Pump
GSR Oil Pump with Pro Drive Gears
Balanced Crank
KMS Block Guard
GSR Girdle (Not Installed Yet)
B16A2 Head:
1 AEM Cam Gear (Only Have one. The Silver one is on back order)
Stock Valvetrain
Golden Eagle LS/Vtec Kit 81mm Bore
AEBS Head Studs
Tranny/Clutch:
ACT Stage 3 6-Puck Clutch AI2-XTR6
JUN Lightened Flywheel (on order 8# I Think)
Y1 JDM Civic Si-r Cable Tranny
Here is the Setup:
B18A1 Block:
B16A2 Pistons
GSR Water Pump
Balanced Crank
KMS Block Guard
B16A2 Head:
Stock Valvetrain
AEBS Head Studs
Tranny/Clutch:
The Paint color is Atomic something I can't remember. I'll get it tomorrow. I do not know if it will hold up yet. It is rated @ 750 Degrees. I guess I'll see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fliptout »</TD></TR><TR><TD CLASS="quote">The Paint color is Atomic something I can't remember. I'll get it tomorrow. I do not know if it will hold up yet. It is rated @ 750 Degrees. I guess I'll see.</TD></TR></TABLE>
cool cool, thanks, i was looking for a color like the for mine to match my other blue accents
the 750 should hold up fine, atleast i think it would
http://www.duplicolor.com/products/engine.html
Blue
Dupli-Color® High Heat Paint with Ceramic
Resists temperatures up to 1200 degrees F, intermittently
Durable ceramic formulation
Tough cured finish resists oil, gas grease, rust, salt, humidity, and solvents
6 colors
EZ Touch® Nozzle
Blue
6 colors
EZ Touch® Nozzle
Integra cost $800.00
B16A2 Head with cams, springs, retainers, Valves, Valve Cover, Keepers, Spring Seats..$400.00
Golden Eagle LS/Vtec Kit: $210.00
Valve Seals: $40.00
Vtec Solenoid: $54.00
99-00 Civic Si Pistons: $40.00
GSR Water Pump: $210.00 (Brand Spankin New)
GSR Water Pump: $110.00 (Brand Spankin New)
Si-R Cable Tranny with Stock LSD : $250.00 (Honest that was the price total)
ACT Stage 3 6-Puck Clutch AI2-XTR6: $100.00 (Very Slightly Used)
Mount Inserts: $45.00
P30 JDM ECU: $25.00 @ the Junkyard LOL
Valve Seals: $40.00
Not really feeling the color and the way you covered the letters, looks like you got lazy with it...But the building of the setup, looks nice...keep up the good work! Remember don't cut corners with this setup...
those are some expensive water pumps, and yeah, why two? or is one an oil pump?
and i would get rid of the blue. always looks ricey.
strip the valve cover and paint it with "crinkle" black. don't paint the letters. the other blue bits, just strip the paint.
good luck with the rest of your build.
LOL Yeah one is the Oil Pump. Yes I got new rings. I am going to take the blue off of the Lettering. The Blue may look Ricey but it looks better than the corroding flat black color that it was. The car right now is Flat Black.
chippy
Sep 21, 2007 05:59 PM
fliptout
Jul 7, 2006 10:33 PM
B18C1CYA
May 30, 2004 07:14 AM
