Downpipe bolts on turbo sucks!
Old Apr 18, 2002 | 11:40 PM
austrian type-R's Avatar
Default Downpipe bolts on turbo sucks!
I have problems with the bolts from turbo housing to downpipe. I have 3 new bolts, cause I have lost the old ones. Now the news are coming off again. I have used a split ring and a Loctite paste.
I guess from the big heat the split rings will glow out and the Loctate is useless.
Old Apr 18, 2002 | 11:48 PM
Flamenco-T's Avatar
Default Re: Downpipe bolts on turbo sucks! (austrian type-R)
here's what me and sayang did to her car....courtesy of Arturbo's brain
get a 8x1.25mm auto studs, get the 40mm length, or just make sure the one end of it is gonna go all the way or less than then turbine housing
then get a 8mm nuts and some lock washers..
works like a charmm
I used to lose a few DP bolts every other month, this works best..no need for loctite..
stan
[Modified by Flamenco-T, 3:14 AM 4/19/2002]
Old Apr 19, 2002 | 12:11 AM
Default Re: Downpipe bolts on turbo sucks! (Flamenco-T)
Exact what my tuner said...using studs. But I wanted to hear an easier opinion, cause it is a pain in the butt to change the bolts to studs.
Old Apr 19, 2002 | 06:29 AM
echo999's Avatar
New User
You guys using a flex pipe after your DP, and before your cat?
Old Apr 19, 2002 | 07:56 AM
GSRwBOOST's Avatar
Default Re: Downpipe bolts on turbo sucks! (echo999)
buy some safetywire bolts.... the kind you feed wire thoruhg and wire them together, they wont back out on you and if they do.. it wont be very much.. it's used in aircraft and believe me they put out more heat than our manifolds.
sway892
Aug 17, 2005 09:03 PM
swlabhot
Apr 29, 2003 08:19 AM
