what ET do i need on my civic hatch
I have some 15x7 35ET on my car (95 civic 4 door) lowered about 2". I did have to roll my rear fenders. Under hard braking + steering I do get some rubbing in the front but definately nothing to worry about. I would kill to have these wheels in ET 40
Depending on your ride height, you have to adjust camber also. I had to add camber in the rear.
How low are you?
Depending on your ride height, you have to adjust camber also. I had to add camber in the rear.How low are you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">+38 would better than the +35</TD></TR></TABLE>
but will 35 still work on my car?
Yes it would, but:
what height?
what size wheels?
15" ET35 fit in my car but i had to add camber in the rear and roll my fenders. That's with a 15x7
what height?
what size wheels?
You are going to have to roll your fenders in the rear at least and can't have any sort of camber kit. At that height you can't have any camber because the wheel sticks out too much. ET35 is low for civics. You are going to rub in the front for sure at that height, specially with lots of camber. Which you will HAVE to run.
with the 35 offset with a 6.5" width, you should be ok...with a 7 inch wide wheel, you are pushing it on rubbing and too narrow of a tire. if you can, get a 205/50r15 tire with a 7" wide wheel with a 38mm positive offset.
the all out kid
Suspension & Brakes
Jan 31, 2009 10:07 AM
Richard.
Sep 21, 2003 09:04 AM
watacivic
May 1, 2003 08:45 PM
