Old Apr 6, 2015, 09:34 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Excessive air blowing from oil fill cap hole ?
Old Jul 4, 2006 | 07:10 AM
AnAccordIsForever's Avatar
Default Excessive air blowing from oil fill cap hole ?
When I remove the oil fill cap (F23A1) with the engine running, a lot of "air" blows out from the fill hole. As if there is small blower inside that is blowing the vapors out. Is this normal ?
Old Jul 4, 2006 | 07:38 AM
Tech-Nics's Avatar
thats seems normal all my other cars have done the same. and you can somtimes see the small hint of smoke coming out aswell...never helped me lead to think its somthing wrong....
Old Jul 4, 2006 | 07:42 AM
Ross 2.0's Avatar
In a Junkyard near you.
That's normal unless it feels like a wind coming out, that could be a sign of blowby if it's excessive. But normally it's just the air being displaced by the pistons
Old Jul 4, 2006 | 07:53 AM
Default Re: (MooGoCow3)
well it is certainly not a light gentle movement of air. It is fairly strong. You can feel it hit your hand pretty good about 6" from the hole. Definitely much more than my other car which is an Acura MDX (3.5L V6 engine). Let me see if I can post a audio or video of it...
Old Jul 4, 2006 | 08:00 AM
Ross 2.0's Avatar
Default Re: (AnAccordIsForever)
Well it's going to sound like a loud muffler. that part is normal, a leakdown test might be in order
Old Jul 4, 2006 | 08:12 AM
yes thats right. sounds like a muffler as soon as I pop the cap.
will a compression test tell me if there is a problem ? I know it wont tell me "where" the problem is but I'd be able to do that much quicker than a leak-down test.
Old Jul 4, 2006 | 08:15 AM
Ross 2.0's Avatar
A compression test won't be as accurate to your issue as a leakdown test but it could help out some
Old goat
Nov 19, 2010 06:54 PM
Frickr
Nov 10, 2007 07:56 PM
dabig1
May 22, 2005 07:40 PM
Infinity_Racer
Nov 8, 2003 09:45 AM
Infinity_Racer
16
Nov 6, 2003 11:11 PM
