Where i can find oil filter part #?? (searched)
for my H22 but it looks a little small so i want to find the part # to see if its the right part... Are the B and H series filters the same size?
it says "Made In France"
wtf?
i know that maybe the part # is different from place to place so is there any webside that i can find any info about this?
wtf?i know that maybe the part # is different from place to place so is there any webside that i can find any info about this?
all filters are the same and they are produced in many factories over the world.
There were 2 types of filter bigger and smaller ones. But all of them fit prelude.
I'm guessing from your post that you went to a Honda dealership and the filter they gave you was smaller than what you're used to. About 2 years ago they stopped making the large-diameter filters and just recommended the smaller ones for Preludes, Accords, etc, which kinda pissed me off. Now I buy K&N filters, even though they're like $11. But you're supposed to be able to use the smaller stock filters without a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudemanDan »</TD></TR><TR><TD CLASS="quote">I'm guessing from your post that you went to a Honda dealership and the filter they gave you was smaller than what you're used to. About 2 years ago they stopped making the large-diameter filters and just recommended the smaller ones for Preludes, Accords, etc, which kinda pissed me off. Now I buy K&N filters, even though they're like $11. But you're supposed to be able to use the smaller stock filters without a problem.</TD></TR></TABLE>
yeap...
any change in performance???
yeap...
none from the butt dyno... but if you want to.. you can use the S2000 filter... just don't use the Insight oil filter... lol...
yea.. the Insight has its own oil filter...
here's the part number you wanted though....
15400-PT7-005
15400-PT7-005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 »</TD></TR><TR><TD CLASS="quote">none from the butt dyno... but if you want to.. you can use the S2000 filter... just don't use the Insight oil filter... lol...
15400-PT7-005</TD></TR></TABLE>
mine is 15400-RBA-F01
it seems that all the lude filters start with 15400
**edit** just noticed that: the S2000 filter fits the h22? any benefits, better oil flow or more oil pressure?
Modified by Buffalo at 10:48 PM 7/4/2006
I just found the website of Purflux, one of the companys that makes oil/fuel filters for honda and the one that make the filter i've got, and i found out that the new filters have smaller diametre but are a little longer so they have almost the same filtering capacity with the old ones. Also the S2000 filters are wider but shorter so i ques they are the same ****... it may be only a matter of clearance
EBPSI
Dec 9, 2001 05:56 PM
