Engine Load Detector
Old Jul 4, 2006 | 06:52 AM
garyc17's Avatar
Default Engine Load Detector
Anyone knows what will happen if I am getting a voltage of less than 4.5V from my Engine Load Detector? I am getting a reading of only 3V. I have been trying to trace a random problem of bogging at constant throttle input. I was wondering if replacing the ELD will help? I was also thinking that my fuel injection main relay might be faulty. Is it possible that the relay internal contact has worn out causing inconsistent fuel pump operation?
Old Jul 4, 2006 | 10:18 AM
mtber's Avatar
Default Re: Engine Load Detector (garyc17)
ELD is usually thrown when there is a short in the wiring harness & the alternator fuse blows.
(In the cases I have seen)
Old Jul 4, 2006 | 10:28 AM
itr1244's Avatar
Default Re: Engine Load Detector (mtber)
and i heard the ELD is a part of the fuse box and it can't be changed by itself
so if u were to change that part. u have to swap out the whole fuse box
Old Jul 4, 2006 | 05:24 PM
Chris F's Avatar
Do you have VAFC or Hondata? Mine does the same. I can watch the A/F ratio go way lean whe it happens like the fuel's geting cut off at very light throttle. I blame the Hondata.
leem23vtec
Feb 10, 2022 09:35 AM
Emmanuel2112
Mar 27, 2010 04:49 PM
civickiller
10
Aug 25, 2009 06:52 AM
H22 CD5
Jan 4, 2007 07:10 PM
91civicmoneypit
10
Feb 24, 2005 11:11 PM
