Engine Load Detector
Anyone knows what will happen if I am getting a voltage of less than 4.5V from my Engine Load Detector? I am getting a reading of only 3V. I have been trying to trace a random problem of bogging at constant throttle input. I was wondering if replacing the ELD will help? I was also thinking that my fuel injection main relay might be faulty. Is it possible that the relay internal contact has worn out causing inconsistent fuel pump operation?
Do you have VAFC or Hondata? Mine does the same. I can watch the A/F ratio go way lean whe it happens like the fuel's geting cut off at very light throttle. I blame the Hondata.
H22 CD5
Jan 4, 2007 07:10 PM
91civicmoneypit
10
Feb 24, 2005 11:11 PM
