where to buy less expensive Oxygen sensor, '95 civic???
Old Jul 4, 2006 | 06:10 AM
timsch75's Avatar
Default where to buy less expensive Oxygen sensor, '95 civic???
I've found that the O2 sensor costs almost $200 from the places online that I usually get my parts. I hope someone can tell me where to go to get one for less than that. I did find a cheap one here:
http://rywire.com/store/denso-...ac0aa
but it says it's for a B-series engine, and I've got the D.
Old Jul 4, 2006 | 06:48 AM
JSPECSIR's Avatar
Default Re: where to buy less expensive Oxygen sensor, '95 civic??? (timsch75)
the first one i bought came from nopi. it was $38 and it was cheaper than the$170 one because it didnt have a connector on it. so any way 4 butt connectors later no more check engine light. but the one from nopi was made by NTK/NGK but its worked good for over 3 years. also you can go to most autoparts stores and tell them you need a universal 1,3,or, 4 wire o2 sensor, and get one that way and just butt or solder the wires together. just make sure it has the correct threads, so take the old one with you.
Old Jul 4, 2006 | 06:58 AM
SkoundrelUSA's Avatar
cute little bastard
http://www.sparkplugs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timsch75 &raquo;</TD></TR><TR><TD CLASS="quote">but it says it's for a B-series engine, and I've got the D.</TD></TR></TABLE>
Both will thread in, just depends how many wires the wiring is on your harness. What model Civic do you have? EX?
Old Jul 4, 2006 | 07:04 AM
cambopheonix56's Avatar
Default Re: where to buy less expensive Oxygen sensor, '95 civic??? (SkoundrelUSA)
I bought a universal o2 one of eBay for my si and it works just fine. Cost like $50.
Old Jul 4, 2006 | 07:14 AM
nocturnaldragon's Avatar
A universal from autozone or something should work as well, you just have to wire it up to your harness. BTW the connectors they give you are ****, just solder and heat shrink tape them
Old Jul 4, 2006 | 07:42 AM
timsch75's Avatar
Yeah, it's an EX. I'll go check the # of wires. As far as soldering goes, I've read on this forum to NOT solder because it can change the resistances of the wires and wind up throwing the CEL.
Old Jul 4, 2006 | 10:04 AM
cute little bastard
Default Re: (timsch75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timsch75 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, it's an EX. I'll go check the # of wires. As far as soldering goes, I've read on this forum to NOT solder because it can change the resistances of the wires and wind up throwing the CEL.</TD></TR></TABLE>
Exs came with 4-wire. So any 4-wire will work. But still get one for a D-series because the length might not be long enough. I'm pretty sure D-series O2s (at the exhaust manifold) are quite short though so it still should be fine.
vrotsos991
Honda Civic (2001 - 2005)
13
Nov 14, 2011 06:31 AM
D16A6killer
Sep 13, 2010 08:26 PM
Beave0101
12
Nov 22, 2004 12:36 PM
turrismaldon
Jun 19, 2002 05:55 AM
eTec
May 31, 2002 08:50 PM
