Transmission / clutch help. please!!!
Old Jul 3, 2006 | 11:48 PM
sencarus's Avatar
Default Transmission / clutch help. please!!!
I just replaced my manual transmission in a 95 civic 1.5L LX. I also replaced the pilot bearing, release bearing, clutch disk and pressure plate. Everything was going smoothly. I reversed out of my carport and driveway, about 40 feet, and it sounded good. I put the car into 1st gear, and about 5 feet later, I heard and felt a "pop" sound. Now the car wont move. The shifter feels like it is going into gear, but it will not engage. There is a faint grinding noise when it is any gear and in neutral, but the noise disappears when I depress the clutch pedal. The car can be pushed while in gear. Any suggestions would be greatly appreciated. Thanks, Bryan
Old Jul 4, 2006 | 12:04 AM
kr's Avatar
kr
Default Re: Transmission / clutch help. please!!! (sencarus)
did you put grease on the shaft where the throwout bearing goes?
Did you torque everything down to factory spec?
Old Jul 4, 2006 | 12:05 AM
kr's Avatar
kr
Default Re: Transmission / clutch help. please!!! (kr)
And did you bleed the clutch.
Old Jul 4, 2006 | 12:40 AM
Sleepy_Red_hatch's Avatar
flywheel bolt backed out? are you sure you know how to install a clutch?
Old Jul 4, 2006 | 11:19 AM
j-corleon's Avatar
get under your car and see if one of your axles popped out, thats probably is whats causing it.
Old Jul 4, 2006 | 12:24 PM
sencarus's Avatar
Default Re: Transmission / clutch help. please!!! (j-corleon)
Sure enough, I got under the car, and the drivers side axel had popped out. I havent had a chance to fix it yet, but would that cause both wheels to stop spinning? As you can see, I am not very automotive literate. Thanks for your help,
Bryan
Old Jul 4, 2006 | 12:47 PM
j-corleon's Avatar
yeh, it will cause the car not to move at all. just pop it back in and you should be good.
Lenne
Transmission & Drivetrain
Aug 4, 2011 03:28 PM
building boost
May 18, 2008 09:18 PM
antivic
Jul 13, 2006 02:13 PM
oinkus
Apr 19, 2005 05:06 PM
accordinated
Sep 3, 2004 01:32 PM
