Is it worth building the B18A1....
Old Jul 3, 2006 | 09:57 PM
1fastvtec's Avatar
Default Is it worth building the B18A1....
Have a serious question for everyone with experience with the B18A in the 92-93' DA's. I drive the car roughly 78miles round' trip a day. I want to keep my A/C and P/S. I plan on boosting, and want a built motor to compliment the turbo setup. I had thought about an LS/Vtec setup, but I have been told their not reliable. I have also considered the usual B18C swap, but don't think I can bolt-on my A/C and P/S to the new motor. So, I thought what about building the motor I have? That way I could keep my A/C & P/S. But, what kind of beating can that particular engine take? I am after roughly 300whp daily. Any opinions would be greatly appreciated. Please keep your not-so-nice comments to yourselves, I have done a few different searches on this one and came up with nothing.
Oh, and the turbo setup will be either DRAG or Turbonetics with a custom-spec turbo.
Old Jul 3, 2006 | 10:01 PM
lVlemphizStylez's Avatar
Default Re: Is it worth building the B18A1.... (1fastvtec)
a boosted b18b can see 300 whp with a t3/t4 and a good tune...i wouldnt go too far over 300 whp on the stock motor though...
Old Jul 4, 2006 | 12:50 AM
ninety-five_DB's Avatar
Default Re: Is it worth building the B18A1.... (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">a boosted b18b can see 300 whp with a t3/t4 and a good tune...i wouldnt go too far over 300 whp on the stock motor though...</TD></TR></TABLE>
really?...your givin' me evil thoughts for mines
Old Jul 4, 2006 | 05:51 AM
H23 Power's Avatar
your a/c and p/s will bolt to any B series motor. But yes, you could also turbo to the tune of close to 300 whp.
Old Jul 4, 2006 | 07:16 AM
1fastvtec's Avatar
So, can I use the same brackets if I decide to swap for the AC & PS? I guess it wouldn't be to hard to obtain a set, huh!? I appreciate the input fellas.
Old Jul 4, 2006 | 07:22 AM
mike9571's Avatar
Default Re: Is it worth building the B18A1.... (H23 Power)
First off the ls/v setup is very reliable if done right (search better). There are many ls/v setups out there that are driven daily.
here
https://honda-tech.com/zerothread/1676914
Old Jul 4, 2006 | 09:30 AM
Nevets's Avatar
Default Re: Is it worth building the B18A1.... (mike9571)
Because of the cramped engine bay in DA's, keeping your a/c and p/s is difficult when going turbo.
However, i think Full-Race makes a turbo kit where you are able to keep both. Their kits are a little on the expensive side but im not really sure how much youre willing to spend.
Old Jul 4, 2006 | 09:36 AM
H23 Power's Avatar
Default Re: (1fastvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastvtec &raquo;</TD></TR><TR><TD CLASS="quote">So, can I use the same brackets if I decide to swap for the AC & PS? I guess it wouldn't be to hard to obtain a set, huh!? I appreciate the input fellas. </TD></TR></TABLE>
same brackets as current, because your still going to have a b-series they will bolt right up.
Old Jul 4, 2006 | 10:03 AM
riceball777's Avatar
i tryed to keep ac and could not do it
the engine bay in 90-93 integras are so much smaller than dc's and eg's. it makes it almost impossible to keep ac when going with a deacent turbo set up. the ac line are compleatly in the way and are ran different than 94+ cars.
ps wont be a problem to keep
Old Jul 4, 2006 | 11:00 AM
AViciousTHRUST's Avatar
for the price of an Ls/v setup youi might as well go with the 404s and nice port and polish some ARP rod bolts, and like 6 psi and you be straight
Old Jul 6, 2006 | 11:44 AM
1fastvtec's Avatar
See, I thought the LS/Vtec setups were very reliable. But, I have talked with alot of people that say otherwise. I am doing alot of research, beacause of the fact that I may not boost for awhile. I do roughly 100miles round' trip a day, and the A/C is important to me. But, if I get this new position I'm hoping for, I will travel roughly 10miles a day. Then, it won't be such a big deal to keep it because I'm not doing as much driving. I'm not going for ultimate top-end power goals. I want something that is fun, reliable, and has the ability for more if I want. Maybe the LS/Vtec would be a good starting point. Run that all-motor, then consider boosting later. I do appreciate all the help.
Old Jul 6, 2006 | 07:52 PM
1fastvtec's Avatar
Heres a question, has anyone swapped an H22 into a DA6 chassis? I know the engine bay is tight, but has it been done without extensive modification to the chassis itself?
center66ljk
May 13, 2016 06:12 PM
DC2_8.2K
Apr 18, 2007 03:55 AM
Acura_I-RS
Jun 8, 2003 10:05 PM
whitemike1644
Nov 21, 2002 08:52 PM
