Oil filter for 97 Lude
Old Jul 3, 2006 | 08:41 PM
henizwhoa's Avatar
Default Oil filter for 97 Lude
I'm having trouble removing this damn oil filter for my 97 lude. The filter that's on it don't have a grip at the end which makes it dificult to remove. I'm trying avoid removing it from the bottom of the car. Is there a trick to remove from the top engine bay? I've try all the available oil filter wrench but there's not that much room in the engine bay.
TIA
Old Jul 4, 2006 | 06:21 AM
smo0th's Avatar
I just changed mine on my car last weekend. Just use your left hand and reach down there backwards to get a good grip on it. It is very hard to do with your right hand because you can angle your right hand enough to get a good grip.
Old Jul 4, 2006 | 06:45 AM
prelude1897's Avatar
Default Re: (smo0th)
just go to your local auto part store and ask for an oil filter remover. They look like overside plyers almost. I use this when I change my oil and works everytime
Old Jul 4, 2006 | 08:01 AM
TruNinja619's Avatar
Default Re: Oil filter for 97 Lude (henizwhoa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by henizwhoa &raquo;</TD></TR><TR><TD CLASS="quote">I'm having trouble removing this damn oil filter for my 97 lude. The filter that's on it don't have a grip at the end which makes it dificult to remove. I'm trying avoid removing it from the bottom of the car. Is there a trick to remove from the top engine bay? I've try all the available oil filter wrench but there's not that much room in the engine bay.
TIA</TD></TR></TABLE>
oh.. you must have a type SH then right?
this is what I basically use when I have to deal with them:
yea.. if its your first time.. I feel you're paint and know it can be a PITA.. hence why I bought that small rachet (mines a flex head) just for the Type SH when I do oil changes (now I use it all the time for oil filters.. )... but yea.. I've seen oil filters at more worst positions than the Type SH (ie IS300, Ford F-150, etc..)
Old Jul 4, 2006 | 01:05 PM
henizwhoa's Avatar
Default Re: Oil filter for 97 Lude (TruNinja619)
yahoo, that @#$ works. Head out to autozone and picked the wrench up. One good turn and I used my hand to take out the old filter. thanks TruNinja619
Old Jul 4, 2006 | 05:14 PM
93h22a1vtec's Avatar
stick a screwdriver right through the bitch
namewasdallas
Jun 2, 2010 08:48 AM
1LowSol
31
Feb 22, 2009 05:55 PM
piggydog
Jun 21, 2007 01:58 PM
Understeer
Jun 7, 2003 10:58 AM
no_limit
Aug 2, 2001 03:44 AM
