Need help w/ Vortech FMU... how to install
Old Apr 18, 2002 | 08:17 PM
sushibug's Avatar
Default Need help w/ Vortech FMU... how to install
I figure I will install it in my auto lab class tomorrow, it being the vortech 12:1 fmu i just got in the mail. is it supposed to say "vortech" anywhere on it? mine has zero writing on it. and is it supposed to have an oversized diaphragm? by oversized, i mean i can see two diaphragms sticking out of the sides.
but the real question, there are three outlets to it. i'm guessing the top one Ts off into a vacuum line? does it matter which one? and the two bottom ones... i'm guessing fuel in/fuel out, would the bottom one be the "out" one? last question, where is the best place to tap into the fuel hose. before the stock FPR? if you guys have any other installation tips/suggestions let me know... thanks
i'd post pictures of it but my digi camera is broken...
[Modified by sushibug, 5:18 AM 4/19/2002]
Old Apr 18, 2002 | 09:35 PM
b16ahybrid's Avatar
Default Re: Need help w/ Vortech FMU... how to install (sushibug)
It's best to tap into the fuel return line after the fpr.
The small port is the boost vacuume line.
With the boost port on top (facing up) the side port is the fuel inlet (comes from the fpr) and the port on the bottom (sticking strait out the bottom) is the fuel return line to the fuel tank.
Old Apr 18, 2002 | 09:49 PM
SlowB16's Avatar
Default Re: Need help w/ Vortech FMU... how to install (b16ahybrid)
what he said
Old Apr 18, 2002 | 10:25 PM
sushibug's Avatar
Default Re: Need help w/ Vortech FMU... how to install (SlowB16)
you guys think its okay to run around w/ the stock fuel pump on 5.5psi? i have enough money to buy the msd inline fuel pump from summitracing but i wanted to have some backup money in case something else went wrong etc.
[Modified by sushibug, 7:26 AM 4/19/2002]
Old Apr 18, 2002 | 10:41 PM
SlowB16's Avatar
Get a GSX pump from an Eclipse. I am at 5 psi with the fmu on stock injectors and it works fine. Other people on here will say dont do what I am telling you , but it works for me.
ityab0y
Nov 6, 2005 09:21 AM
JDMs1eeper
Jul 13, 2003 09:04 PM
wanttorace
Jun 5, 2003 02:32 PM
jspek29
May 3, 2003 07:08 PM
1.8EG-T
Dec 30, 2001 03:12 PM
