what would make a 70-100k motor run weaker if its not the compression???
can anyone help me, i know my motor isnt running to its full potential, it has stock internals but should be running stronger, would the old *** bearings make it lose power?
and its not my driving so leave that out
Do a leak down test also.
Cap, rotor, wires, sparkplugs, bad sensor somewhere. O2 sensor
Corroded grounds. Plugged/worn-out fuel injectors and/or fuel pump.
Ignition and/or Cam timing,
Carbonned up exhaust ports and exhaust system restricts exhaust flow.
Clogged air filter
Anything else?
John
Clogged air filter
Anything else?
John
N hatch
14
Jul 11, 2004 06:21 PM
