brake pedal
Old Jul 3, 2006 | 02:08 PM
higgunscrx's Avatar
Default brake pedal
ok so i changed my alternator a while ago and unbolted and moved the mc to the side to remove the alt. since then when its been really hot, i notice that when i go to brake my brake pedal just keeps going towards the floor. the car stops but the pedal just keeps going though and it takes a lil bit longer to stop the car. is my mc gone or going or what. the fluid is still there i thought maybe it was leaking but its not.
wtf is wrong with my car anyone??
Old Jul 3, 2006 | 02:13 PM
yz125rider21's Avatar
did you get air in your lines????
Old Jul 3, 2006 | 02:16 PM
e jay one's Avatar
Default Re: (yz125rider21)
if its not leaking any where blead the brakes.
Old Jul 3, 2006 | 02:20 PM
higgunscrx's Avatar
i never took any lines off just unbolted the mc from the brake booster, should i still blead the brakes?
Old Jul 3, 2006 | 02:22 PM
JokerTypeR's Avatar
Default Re: (higgunscrx)
Bleed 'em and check your results. Sounds like the culprit. Even without lines moving, there's a possibility you moved something, or binded something and it let a little bit in.
Old Jul 3, 2006 | 02:26 PM
ya like I said probably got air in lines...but isnt there a thing to adjust on the mc or am I think on the brake booster but thats by the pedal and I am sure you didnt touch anything there...
Old Jul 3, 2006 | 03:01 PM
mahatma's Avatar
Sounds to me like your MC took a dump. May be totally unrelated to moving it for the alt swap
Old Jul 3, 2006 | 03:07 PM
JokerTypeR's Avatar
Default Re: (mahatma)
Or it's half related. It was on it's way out, and when it was moved it finally triggered something...
Old Jul 3, 2006 | 06:02 PM
aXhatch's Avatar
Default Re: (JokerTypeR)
or ti would be that when u took your MC out you got air IN the MC.
air in the MC feels like you described pretty much. and it will never go away with just bleeding the brakes. you have to bench bleed the MC everytime you take it off/out.
Old Jul 3, 2006 | 06:28 PM
crx2nr822's Avatar
Default Re: (aXhatch)
Bleed the lines again and post results
tommyofyork
Apr 8, 2007 05:45 PM
KrenzyRyan
Jun 3, 2006 05:37 PM
UltimX
21
Feb 8, 2006 08:29 PM
The Hooligan
May 5, 2005 03:32 PM
H.crx-si
Jul 6, 2003 10:05 AM
