Best Vtec Contoller?
Old Jul 3, 2006 | 02:00 PM
crxfriday13's Avatar
Default Best Vtec Contoller?
I have heard different things and my friend has an MSD window switch with those fuse pills.
Old Jul 3, 2006 | 02:11 PM
yz125rider21's Avatar
msd switch is the cheap way to go to activate vtec...acutal way is get p28 or any obd1 ecu and go fmor there...Apexi is what a lot people use for controllers
Old Jul 3, 2006 | 02:45 PM
JokerTypeR's Avatar
Default Re: (yz125rider21)
I've played a little bit with the first version of the Apexi VAFC, and alot with the second model...both are easy to use. I don't know about install, though.
Old Jul 3, 2006 | 09:08 PM
La EF-8's Avatar
joker, are they any good?
Old Jul 3, 2006 | 09:14 PM
they are good but cost a pretty penny...just sear on here for apexi vtec controllers and you will find everything you need....
Old Jul 3, 2006 | 09:17 PM
JokerTypeR's Avatar
The second version I got to play with more...didn't come with an instruction manual (it was already installed int he car I played with it on) and it was fairly easy to figure out, and worked well. We spent about an hour driving in the mountains tinkering and it did everything we wanted it to, but it IS decently expensive.
As for the first model they made, I know alot of companies use it and love it. I haven't really gotten to play with it, so I can't vouch for it.
Good luck, but I say for APEXI's VAFC
Old Jul 3, 2006 | 09:22 PM
La EF-8's Avatar
thanks i was just curious. getting my carpet and frontend is a lil more important right now, but the b16 ia all tuned and running awesome. so everything now is minor stuff
Old Jul 3, 2006 | 09:23 PM
JokerTypeR's Avatar
Default Re: (La EF-8)
Carpet? I've got some of the interior stuff...clips and door sill moldings. Check out my sig for for-sale stuff. Let me know, bro.
Old Jul 3, 2006 | 09:31 PM
La EF-8's Avatar
man i have about as much honda stuff in my garage as you. lol b18 block, 2 heads, tons of valve springs, intake manifold. just abunch of stuff i dont need anymore i have the whole bottom end for an lsvtec just chillin
Old Jul 3, 2006 | 09:45 PM
JokerTypeR's Avatar
Well, let me know on those clips....
You got a thread up? Looking for some parts still, believe it or not...I've got the Si head down there, too...so I'm in the same boat. One block, two heads, one manifold...LoL
Old Jul 3, 2006 | 09:48 PM
La EF-8's Avatar
nahh i dont have a thread up imma work on that tomorrow. if you want i got some friend around here so i can put the word out
Old Jul 4, 2006 | 08:29 AM
JokerTypeR's Avatar
Please do...I'm needin' cash and space in my garage
Old Jul 4, 2006 | 12:02 PM
La EF-8's Avatar
i got you hooked up man i got my friend spreading the good word
Old Jul 4, 2006 | 12:07 PM
JokerTypeR's Avatar
Hardcore, I might have just sold the PR3 pistons.
Old Jul 4, 2006 | 12:08 PM
jedubz's Avatar
I've been wondering about the Buddy Club V-Con... Anyone have any experience with this?
Old Jul 4, 2006 | 12:11 PM
JokerTypeR's Avatar
Default Re: (jedubz)
Looks handy, but it doesn't appear to have any fuel management system...
The VAFC by Apexi allows you to control fuel flow +/- at set intervals.
Old Jul 4, 2006 | 03:32 PM
EF9Fanatic's Avatar
Default Re: Best Vtec Contoller? (crxfriday13)
I have a Field SFC VTEC controller. Its bloody great, allows adjustment of vtec crossover point and air/fuel adjustments of up to plus or minus 30 percent. It also has a speed cut removal function and digital speedo. I have no idea where to buy them from new as I picked mine up second hand off some guy here in NZ.
Old Jul 4, 2006 | 04:15 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Best Vtec Contoller? (keeweelogger)
wiring to obd1 and letting it do its thing
Use a form of tuning if you need to alter it eg neptune hondata or crome.
I would never run a msd setup and or any halfass way when obd1 is just so much easier and nicer.
You could wire it up and stay obd0 run something like turbo edit.
Old Jul 4, 2006 | 08:37 PM
johnjw's Avatar
Default Re: (JokerTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I've played a little bit with the first version of the Apexi VAFC, and alot with the second model...both are easy to use. I don't know about install, though.</TD></TR></TABLE>
easy to use?? I've never experenced "easy to use" w/ either VAFC. Took me along time to adjust everything to a *close* tune. I would highly recomend setting these things up on a dyno, if you dont have access to a dyno(mine is 300 miles away) good luck
Old Jul 4, 2006 | 09:36 PM
slowcrxsib16's Avatar
Default Re: (johnjw)
i used a fields, i like it, i picked it up at nopi last year for 165, got it from island motorsports. i liked it while i had it, i sold it recently, im gonna tune with uberdata and just say the hell with it, vtec.... then boost, life is good
Old Jul 4, 2006 | 10:06 PM
crxnj's Avatar
Default Re: Best Vtec Contoller? (***-assin)
I actually had one of those Buddy club vtec controllers....Bought from a local shop when they were $50.The thing is though i didnt just use the vtec controller and thats it,,,i also had turboedit chip ecu to compensate for the vtec fuel/timing,,i just liked playing with vtec point,cause the higher you moved it the louder the x-over ..I never had any problems with it,its pretty self explanitory and simple to use...Sold it though to some kid around my way..
Old Jul 4, 2006 | 10:44 PM
JokerTypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnjw &raquo;</TD></TR><TR><TD CLASS="quote">
easy to use?? I've never experenced "easy to use" w/ either VAFC. Took me along time to adjust everything to a *close* tune. I would highly recomend setting these things up on a dyno, if you dont have access to a dyno(mine is 300 miles away) good luck </TD></TR></TABLE>Perhaps I should have said it was "easy to access and adjust"?
civiccrazy93
Dec 6, 2004 09:04 AM
s2000june
16
Jan 31, 2004 06:55 PM
uneeklady6o2
Dec 3, 2003 04:53 AM
crooked muffler
Mar 23, 2003 08:51 PM
crux131
Aug 7, 2001 08:56 PM
