ok.. i stripped the bottom bolt on my brake caliper?? now how can i get it out??
i stripped the bottom bolt on my front left wheel brake caliper.. the bottom one and the top has no bolt to remove? how can i get this off now? i need to change my break pads..
mike
mike
If there is enough of the bolt left yes vise grips. Just before you try to loosen it use a propane torch to heat the material around the bolt, it will expand away from the bolt then turn fro all your worth. If there is not enough left to get a good bite, then use a file to file the bolt flat to the surface then drill the right size hole to use an "easyout" any decent "parts store" not autozone should or be able to tell you where to buy one. If your skills aren't up to it any good automotive machine shop should be able to remove it for you. Why not just get an old one from a junk yard an be done with it?
Tom
Tom
LOWLIFEHATCH
25
May 18, 2023 07:14 AM
