Weird JDM H22A problem....Can anyone help?
Old Jul 3, 2006 | 12:52 PM
AnthonyG2003
Guest
Posts: n/a
Default Weird JDM H22A problem....Can anyone help?
Ok, I have a 94 JDM H22A swap in my car. It runs fine and everything except when I go to floor it or get on it...the car hesitates then takes off. I thought it was the timing so I adjusted that. Didnt work! Then I thought it was the TPS so I checked the voltage on that. It was perfect! What else could be causing this!??!
I am open for any suggestions...
Old Jul 3, 2006 | 01:04 PM
JasonST's Avatar
Default Re: Weird JDM H22A problem....Can anyone help? (AnthonyG2003)
Any cel's?
Old Jul 3, 2006 | 01:06 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Weird JDM H22A problem....Can anyone help? (JasonST)
The only time it will throw a CEL is if I am driving on the interstate and then throw it into 4th then the light will come on, but as soon as I turn the car off and back on...it isnt on anymore and wont come on until I do it again.
Old Jul 3, 2006 | 01:30 PM
darkspector's Avatar
valves??
Old Jul 3, 2006 | 02:32 PM
SteveoBA8's Avatar
Default Re: (darkspector)
Check ignition system- plugs,wires,rotor,cap,coil.check/replace fuel filter and fuel pressure.
Sounds like you have a bad electrical connection somewhere causing your cel.
Old Jul 3, 2006 | 05:51 PM
soccmid1587's Avatar
Default Re: (SteveoBA8)
the ecu stores the CEL. Pull it then get back to us.
Old Jul 4, 2006 | 05:43 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (soccmid1587)
I cant seem to find that little peice that flashes the codes...I know where its supposed to be, but im not seeing it...
Old Jul 4, 2006 | 05:52 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (AnthonyG2003)
are the wires of it grn/red, wht/blu, blk/red?
Old Jul 4, 2006 | 06:53 AM
Felt.2's Avatar
reach up under there its somtimes tucked up pretty far
Old Jul 4, 2006 | 11:14 AM
-DC2-'s Avatar
Default Re: (Felt.2)
sounds like timing to me
did you verify with a light that the ignition timing is right?
did you confirm that the cam timing is right, too?
Old Jul 4, 2006 | 11:25 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (DOHCvtecDX)
i know the ignition timing is right, i used a light gun. the cam timing i didnt look at.
Old Jul 4, 2006 | 02:11 PM
SteveoBA8's Avatar
did you jump the service connector while adjusting ignition timing? You have to have it jumped
Old Jul 5, 2006 | 10:19 AM
AnthonyG2003
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">did you jump the service connector while adjusting ignition timing? You have to have it jumped </TD></TR></TABLE>
yep i did that
Old Jul 5, 2006 | 10:55 AM
soundbomber's Avatar
haha if you jumped the service connector then you would know how to pull the codes...it flashes on the gauge cluster when that connector is jumped. just look at the check engine light.
Old Jul 5, 2006 | 12:03 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (soundbomber)
do i need to start the car or do i just turn the key to the run position?
Old Jul 5, 2006 | 12:08 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">haha if you jumped the service connector then you would know how to pull the codes...it flashes on the gauge cluster when that connector is jumped. just look at the check engine light.</TD></TR></TABLE>
It's right behind the radio, access it from the driver's footwell. It might be plugged into a brown rubber thing.
And you only need to turn it to ON position, no need to start the car.
Long light pulse = 10
Short light pulse = 1
Old Jul 5, 2006 | 02:28 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (Finest)
it flashes 1 short time, and repeats after a couple seconds.
Old Jul 5, 2006 | 02:52 PM
AnthonyG2003
Guest
Posts: n/a
bump....
Old Jul 5, 2006 | 03:08 PM
shutta's Avatar
keep turning it off then back to the on postition, when trying to pull a cel once it took liek 20 tries before the ****** would blink for me.. sometimes it's a pain in the *** for some reason.
edit: it also may not show you one if the cel isn't staying on. go drop it into 4th on the highway or whatever to bring up the CEL and only turn off the car once you are ready to check the cel.. I don;t think the ecu would "store" a cel and give you the code when it isn't detecting the problem anymore like that other guy said
Old Jul 5, 2006 | 04:39 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (shutta)
boo on preludes...LOL
Old Jul 6, 2006 | 05:10 PM
AnthonyG2003
Guest
Posts: n/a
ive tried it a bunch of times...and its still throwing a 1 code. Thats for the O2sensor. That wouldnt make the car bog/hessitate like it does would it?
Old Jul 7, 2006 | 03:36 AM
Rudaluda's Avatar
hellz yeah a bad O2 would very much so cause problems.
Old Jul 7, 2006 | 07:00 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (Rudaluda)
well guess i need to replace that then, and see whats up afterwards.
MJT805
Oct 9, 2009 01:33 PM
chrisfisher
Jun 5, 2009 03:47 PM
vtec420kingH22
May 16, 2005 12:42 PM
vtec420kingH22
May 15, 2005 06:44 PM
