how much for radiator ?
Old Jul 3, 2006 | 12:05 PM
tinhnho's Avatar
Default how much for radiator ?
i have a accord coupe 94. My engine was really hot yesterday and i figure out that the radiator is broken. Is it possible to change it at home ? or i have to go somewhere to change it ? How much ? and any recommend place to do it ? thanks alot.
Old Jul 3, 2006 | 12:22 PM
EASY101's Avatar
* B A N N E D *
what do you mean its broken? you have a small leak or what?
Old Jul 3, 2006 | 12:23 PM
tinhnho's Avatar
Default Re: (EASY101)
yea, it's leaking evey time when i add more water to radiator
Old Jul 3, 2006 | 12:38 PM
EASY101's Avatar
* B A N N E D *
you know where its leaking from? If its just a small leak you could probably get away with radiator stop leak for a little while until you get around to replacing your radiator. I'd just start checking around price both new and used radiators. radiators are definitely a DIY if you're even slightly mechanically inclined. not hard at all.
Old Jul 3, 2006 | 12:40 PM
tinhnho's Avatar
thanks for reponse , i will do it later today
Old Jul 3, 2006 | 01:42 PM
pos_cd5's Avatar
Default Re: (tinhnho)
also check to see if your radiator drain plug isnt loose. i hit a curb before and my radiator leaked all its fluids, i thought i had to get a new one but it just knocked the drain plug loose.
Old Jul 3, 2006 | 02:30 PM
jung918's Avatar
Also, it would be a good time to check the hoses too.
Old Jul 3, 2006 | 02:34 PM
YeuEmMaiMai's Avatar
it'll cost about $100 incl shipping
YOu can take it out and install your self in about 1.5 hrs
Old Jul 3, 2006 | 03:37 PM
CB7VTEC's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">it'll cost about $100 incl shipping
YOu can take it out and install your self in about 1.5 hrs</TD></TR></TABLE>
If you go aftermarket, stick with the Koyo brand, excellent quality for the price, & a lifetime warranty
Old Jul 3, 2006 | 05:07 PM
standbackimapro's Avatar
Radiators are Cheap, A stock one is probably around $100 bucks
There easy to put in, and Easy to take out
Itll take you about an hour
Old Jul 5, 2006 | 06:15 AM
tinhnho's Avatar
what website to order ? or store ? So i just need to change the radiator or i need to change anything else ? thanks bro.
BTW, anyone has instruction how to change the radiator ?
Modified by tinhnho at 7:35 AM 7/5/2006
Old Jul 5, 2006 | 06:37 AM
tinhnho's Avatar
i found one from carpartswholesale for $88.83 plus shipping
"1994 Honda ACCORD RADIATOR 4cyl; 2.2L; 132c.i. 1 ROW, PLASTIC TANK,ALUMINUM CORE"
is this one good ? thanks
Old Jul 5, 2006 | 02:14 PM
CB7VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinhnho &raquo;</TD></TR><TR><TD CLASS="quote">i found one from carpartswholesale for $88.83 plus shipping
make sure the warranty is lifetime
dwn2earth922
Sep 12, 2009 10:00 AM
tommyt761
Oct 12, 2006 01:00 PM
FD3S
Dec 15, 2005 08:37 AM
vtecmw
Dec 5, 2005 09:44 AM
kingpen
Oct 31, 2002 12:19 PM
