broke this bolt... any ideas why?!
Old Jul 3, 2006 | 11:10 AM
xfrankx's Avatar
Default broke this bolt... any ideas why?!
i went to the track and when i launched my car this happened..
it wasnt even a hard launch though. i think having a stock rear mount may have done it but im not sure. any ideas?!
Old Jul 3, 2006 | 11:28 AM
unknown0001's Avatar
Default Re: broke this bolt... any ideas why?! (xfrankx)
that's where the rear engine/subframe bracket bolts onto the tranny/engine
Old Jul 3, 2006 | 11:34 AM
xfrankx's Avatar
Default Re: broke this bolt... any ideas why?! (Mr.RHTuner)
yea i know the bolt didnt really break it was the top part of the tranny that broke off. my guess is it flexed and it broke. you guys think a solid rear mount will prevent that from happening again?
Old Jul 3, 2006 | 11:55 AM
Luserkid's Avatar
Stock mounts wouldnt cause that to break unless you torqued the motor so much that the mount count hold and it was on the subframe instead of a mount. Should be fixable if you still have the top part. Youll want it welded back on and then probably run a tap through to make sure the threads are good.
How many mounts are you running?
Old Jul 3, 2006 | 12:03 PM
saywhat's Avatar
Default Re: broke this bolt... any ideas why?! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">How many mounts are you running? </TD></TR></TABLE>
Yeah, I can see if you aren't running the a/c bracket mount and the other transmission mount that would put a lot of stress on that rear mount I am going to jump to conclusions and say those mounts are either not present or not in good shape.
Old Jul 3, 2006 | 02:41 PM
GSRcivicGSR's Avatar
Default Re: broke this bolt... any ideas why?! (saywhat)
yea thats prob the case. i broke mines off. but i came to find out that i only had 1 of those 2 bolts on
Old Jul 3, 2006 | 05:38 PM
needforvtec's Avatar
man that must really suck
Old Jul 3, 2006 | 07:14 PM
GreenEHDriver's Avatar
Default Re: broke this bolt... any ideas why?! (jerrylauj913)
got to get hasports then you can take off the support brakets, haha HASPORT
Old Jul 3, 2006 | 07:15 PM
xfrankx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerrylauj913 &raquo;</TD></TR><TR><TD CLASS="quote">man that must really suck</TD></TR></TABLE>
not really its not like its a hard fix i just wanted to know why it happened.
yea im running 3 mounts no tranny or ac mount but i have had several motors and never had a problem so i dunno.
Freemananana
Jul 5, 2013 09:46 AM
CivicUtah
Sep 18, 2007 02:17 PM
Mr.Meowsome
Dec 1, 2006 11:27 AM
biassj
Apr 13, 2005 07:04 AM
