Compression Numbers for Mini-Me swap and what is the ratio?
Old Jul 3, 2006 | 12:39 AM
pumpkyn's Avatar
Default Compression Numbers for Mini-Me swap and what is the ratio?
Y7 block, Y8 head, OEM Y8 HG
#1 = 175
#2 = 170
#3 = 180
#4 = 175
is that good enough for turbo?
Also what is the compression ratio going to be? from what ive been reading it says 10.23 is that correct?
Old Jul 3, 2006 | 05:56 AM
pumpkyn's Avatar
Default Re: Compression Numbers for Mini-Me swap and what is the ratio? (pumpkyn)
Old Jul 3, 2006 | 07:53 AM
cambopheonix56's Avatar
Well it should be 215ish if the 10.2 compression is right, however, they are very close together which indicates you are alright.
Old Jul 3, 2006 | 10:59 PM
pumpkyn's Avatar
Default Re: Compression Numbers for Mini-Me swap and what is the ratio? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">Well it should be 215ish if the 10.2 compression is right, however, they are very close together which indicates you are alright.</TD></TR></TABLE>
any idea what the ratio could be then and would it be good to trubo it
Old Jul 4, 2006 | 05:01 AM
R1Motorsports.com's Avatar
They could be a little higher, but they are all very even. You'll be fine with a turbo on it.
Old Apr 4, 2011 | 04:19 AM
A-Man's Avatar
guys im gonna bump this,
i want to do this ive had cheap performance increase with dropping a built vtec sohc head on my d16z2 (sohc non vtec) however im a little worried the compressions gonna be a bit high i have 12:1 ycp pistons has anyone tried this and does it make my compression ratio to high?
Old Apr 4, 2011 | 04:43 AM
94EG8's Avatar
Seagull Management
Compression ratio is 12:1 now or will be after the head swap?
Old Apr 4, 2011 | 05:42 AM
A-Man's Avatar
nah currently my non vtec sohc d16 is 12:1 apparently
Old Apr 4, 2011 | 05:56 AM
94EG8's Avatar
Seagull Management
In that case, yes you'll have issues.
bobalee
Nov 4, 2007 08:51 PM
vegaskurt
Jun 25, 2005 08:37 AM
DeadVet
Mar 30, 2005 04:37 PM
whitemike1644
Apr 9, 2003 01:10 PM
