stripped brake rotor retainer screw, what should i do ?
Old Jul 2, 2006 | 05:06 PM
m1nh's Avatar
Default stripped brake rotor retainer screw, what should i do ?
i was going to change my front brake pads and rotors today, but ended up stripping the brake rotor retainer screw so now i cant get the rotor out, i didnt know the screw was that soft, any suggestion on what i can do to get screw out ?
i tried using a screw extractor but it ended up broke in half and part of it is still lodge inside the screw
i havent attempt the other side yet in fear or stripping that side too, so whats the best method to get these screws out without stripping it ?
Old Jul 2, 2006 | 05:11 PM
Uncle Willie's Avatar
Default Re: stripped brake rotor retainer screw, what should i do ? (m1nh)
https://honda-tech.com/zerothread?id=1677387
https://honda-tech.com/zerothread?id=1439058
Old Jul 2, 2006 | 05:46 PM
m1nh's Avatar
Default Re: stripped brake rotor retainer screw, what should i do ? (RIP Indian Larry)
you are the man!, thanks bud
Old Jul 16, 2015 | 11:00 AM
snunicycler's Avatar
I know this is an old thread but I found this searching my problem.
Basically, I stripped out that retaining bolt. I've broken a screw extractor and about 10 drill bits trying to get this bolt out. any other ideas?
Old Jul 16, 2015 | 12:03 PM
oldschoolmaster's Avatar
Hammer and chisel or drill off head then unscrew them after u get rotors off
Old Jul 16, 2015 | 12:11 PM
Thanks!
To clarify though, if I get the head off the screw (and leave the screw in place) the rotor should still come off?
Also, the head is pretty mangled and there is a broken piece of screw extractor in it (hardened steel, just breaks the drill bits) so I'm assuming a chisel is my only real option here? I have some wood chisels, will those work or is there another kind I should look for? thanks!
Old Jul 16, 2015 | 02:53 PM
wunfstgsr's Avatar
Loved
Community Favorite
Those are not even needed imo, my new rotors for my JDM ITR conversion don't have the holes lined up so its said they if they might not line up the screws can be skipped. Gl getting it off.
Old Jul 16, 2015 | 03:04 PM
B_Swapped93's Avatar
it does **** all safety wise it just keeps your rotor on when you remove the wheel, it's "nice" to have but far from needed if you have pad that chew rotor its a pain. just leave it
Old Jul 18, 2015 | 04:18 PM
90Acura's Avatar
FWIW, mine were probably about as tight as possible, when trying to remove them. A sharp chisel turned them loose, after driving a nick into the outer edge of the screw head and then hammering the chisel to turn the screws counter clockwise.
Old Jul 18, 2015 | 04:24 PM
wunfstgsr's Avatar
Loved
Community Favorite
Heat the screw with a torch it will help.
Old Jul 19, 2015 | 12:49 PM
egsleepercivic's Avatar
use an impact screwdriver and you won't have these problems
Amazon.com: Lisle 29200 3/8" Hand Impact Tool Set: Automotive Amazon.com: Lisle 29200 3/8" Hand Impact Tool Set: Automotive
Impact Driver Set at AutoZone.com - Best Impact Driver Set Parts for Cars, Trucks & SUVS
Impact Screwdriver Set with Case
Old Jul 22, 2015 | 03:46 AM
blackeg's Avatar
word i always hit it with a torch. use the #3 phillips not a more common #2 its bigger and combined with a cordless impact (i use my 18v dewalt) then pop right off. when you go and re install put a tiny bit of antiseize on it.
if its stuck just get a drill bit probably something around 3/8 and just drill out the head of the screw. once you do that it relieves the pressure on the rotor and you can take it off
Old Oct 8, 2019 | 11:57 AM
Larry_L's Avatar
The screw extractor is made of hardened tool steel. You will not be able to drill through it with conventional drill bits. Remove the rotor and hub as an assembly, then decide if you want to take it to a machine shop and let them get it apart, or buy another hub and rotor.
Old Oct 9, 2019 | 10:15 AM
tony_2018's Avatar
Fish Twig
bumping an old thread....eh
I use a impact driver with the right bit.
Old Oct 9, 2019 | 05:47 PM
wunfstgsr's Avatar
Loved
Community Favorite
4 years later im back to say you don't need those damn screws. Take them off and leave them off..
EX-T
Feb 18, 2009 11:55 AM
Meatwad1355
Apr 4, 2007 10:39 AM
E-brake or Handbrake
54
Oct 11, 2004 03:02 PM
persain488
Sep 28, 2004 04:30 PM
leechungsr
Aug 25, 2001 03:39 PM
