h22 in civic help
Old Jul 2, 2006 | 10:41 AM
djsire's Avatar
Default h22 in civic help
the car just died on him while he was cruising. now when he cranks it, you hear a strong pop and the dash ligts get dim and sometimes.i hear clicking form the main relay area, occasionally
but fuel pump is priming.
ocasianally the motor will almost crank. like 1 in 15 tries.
i dont konw what to check for.
we tried push starting but the wheels just locked up when he let go of the clutch.
any suggestions
Old Jul 2, 2006 | 11:13 AM
Hawkze_2.3's Avatar
Default Re: h22 in civic help (djsire)
Timing belt?
Old Jul 2, 2006 | 12:22 PM
PrettyLude's Avatar
also check for spark
JasonST's Avatar
Default Re: h22 in civic help (Hawkze_2.3)
Yeah unfortunatly sounds like the timing belt could have broken, to check just take the valve cover off and look at the belt, in that case, you probly bent at least 1 valve, maybe all of em, first thing I'd do though is check that belt. Good luck.
Old Jul 2, 2006 | 06:47 PM
djsire's Avatar
so i should be able. to turn the crank over by hand though correct>?
Old Jul 4, 2006 | 12:30 AM
djsire's Avatar
nope timing belt wasnt broken. and cant turn the motor over even with spark plugs out andstarter removed
Old Jul 7, 2006 | 11:16 AM
djsire's Avatar
anyone!!!!
Old Jul 7, 2006 | 12:48 PM
Ur_A_Towel's Avatar
sounds like the engine seized. oil filter clogged? check quality and quantity of oil? How many miles on the engine?
Old Jul 7, 2006 | 02:04 PM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">nope timing belt wasnt broken. and cant turn the motor over even with spark plugs out andstarter removed</TD></TR></TABLE>
That doesn't sound good. Car is in neutral, right?
Old Jul 7, 2006 | 08:46 PM
djsire's Avatar
Default Re: h22 in civic help (flyrod)
yes the car was in nuetral and motor wouldnt turn. i drained the oil didint see any metal. the car was running 2 quarts of 20/50 and 3 quarts of 10/40
thekeysarebroke
15
Oct 1, 2012 05:35 AM
KiDSoL
Apr 5, 2012 04:30 PM
BlackHonduh
Feb 28, 2008 07:38 PM
VTEC_PRODUCTION
Apr 7, 2007 01:55 PM
1994hondaprelude_dude
Jan 29, 2007 08:10 PM
