MY CAR IS ON FIRE!!
Old Apr 6, 2007 | 04:18 PM
VTEC_PRODUCTION's Avatar
Default MY CAR IS ON FIRE!!
well it actually isnt but its about to be...my car will not start...i know...search button right??? wrong...it turns over...its getting gas...the relay is working properly and so if the fuel pump...i replaced fuel filter...i cannot check for spark since i dont have tools handy and there is a stupid cover over the plugs...but i can tell you that it sounds like it wants to starts when first cranking in between starts but it just wont start...now i heard something like a timing belt issue since my car died while driving it but it the timing belt breaks doesnt it make like a clunk noise and all the valves are bent? i dont know what my next move is...i would like some help please....
Old Apr 6, 2007 | 04:21 PM
MATiC's Avatar
the next move would be to pull the valve cover and check to see if your timing belt is broken.. if it isn't, check for spark..the "ghetto" way i was told is to place something metal into a spark plug wire and touch the other end to a ground..dunno if this is the safest way..!
Old Apr 6, 2007 | 04:43 PM
youknowimwhite's Avatar
Default Re: MY CAR IS ON FIRE!! (Acura_Integra_Type_R)
an easy way to check for spark is to shove a screw driver in the spark plug wire lay it across the valve cover and have a friend turn it over... look for spark
Old Apr 6, 2007 | 04:46 PM
LordAphotic's Avatar
have you even touched the ignition system?
its 3 things to work not just the 2 your checked.
Fuel + Crank + Spark
pull out one of your spark plug cables and then put a sparkplug on it put it somewhere safe where you can monitor it. have someone crank the engine consistently for like 15 seconds. check for a spark.
its usually the simpler things and not the more complicated things like bad timming or massive loss of compression.
one thing that makes me iffy though is that you say you crank it and now and then it acts like it wants to start? that sounds like a fuel problem to me.... are you sure your fuel pump works? how do you know it works?
Old Apr 7, 2007 | 05:02 AM
Default Re: (LordAphotic)
my fuel pump works...i know this because i can hear the main replay clicking and i took out the back seat and put my ear up to the fuel pump and hear it run...
Old Apr 7, 2007 | 07:27 AM
k624ash's Avatar
Default Re: (Acura_Integra_Type_R)
put out the fire, replace anything damaged by the fire
Old Apr 7, 2007 | 09:46 AM
.one lane's Avatar
.likes trains
I would check your dizzy cap/rotor, and your ignitor coil.
Old Apr 7, 2007 | 10:30 AM
Hondas_Only's Avatar
if your car died while you were driving, check your distributor. that happened to me once.
Old Apr 7, 2007 | 01:55 PM
Default Re: (Hondas_Only)
actually i found out its the timing belt GOOD CALL DUDE!!! slipped teeth and now need to replace...thanks dudes...
sleet_22
Dec 9, 2013 02:09 PM
trentwilsn03
19
Jul 17, 2011 03:50 PM
dismemberment
11
Mar 1, 2009 07:06 PM
1994hondaprelude_dude
Jan 29, 2007 08:10 PM
the soL that could
11
May 30, 2006 07:58 AM
