Urgent question...
Old Jul 1, 2006 | 11:54 PM
srg's Avatar
srg
Default Urgent question...
Hello Guys,
I bought 93 del sol nearly 2 months ago.. it's del sol si with D16z6 engine so I bought brembo rotors for sohc del sol and they wont fit.. after that I bought DOHC rotors and they fit ok.. Now I need to buy axles and I don't know which should I get.. can you please tell me what axles will fit my car? SOHC or DOHC?
Thanks
Old Jul 2, 2006 | 01:03 AM
hatchi's Avatar
Default Re: Urgent question... (srg)
if you are running sohc motor then buy sohc
if you have dohc then get dohc.
Old Jul 2, 2006 | 01:12 AM
prison_snitch's Avatar
nevermind i dont know
Old Jul 2, 2006 | 02:46 AM
srg's Avatar
srg
Default Re: Urgent question... (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">if you are running sohc motor then buy sohc
if you have dohc then get dohc. </TD></TR></TABLE>
Are you shure? I'm running Turbo SOHC D16z6...
Let me know good place to buy axles
Old Jul 2, 2006 | 03:24 AM
Syndacate's Avatar
oh, ur running turbo...so u'll need a high performance axle, not a stock one...yeah, you should have included that..
I would try to go aftermarket, I'm sure some company makes one that's not a cast billet of steel and doesn't cost a fortune for somebody in ur position...you don't need top of the line, but if u launch u can snap an axle if u keep that up :-\
Old Jul 2, 2006 | 04:34 AM
si0385.'s Avatar
Default Re: (Syndacate)
you should be alright with some stock axles it all depends how much power your putting down but 9 outa 10 times you will be fine with stock but you will need single cam axles because im prety sure one will be longer than the other
Old Jul 2, 2006 | 11:59 AM
srg's Avatar
srg
My car has 200hp.. up for some answers...
Old Jul 2, 2006 | 01:09 PM
gold_ef's Avatar
what the hell is so hard about this, you have a sohc therefore you need sohc axles, not dohc axles because they wont fit in the ******* transmission.
turbo or not its sohc, so you need sohc axles.
stock axles can handle 200 hp too
Old Jul 2, 2006 | 01:41 PM
si0385.'s Avatar
Default Re: (gold_ef)
as our fellow n00b gold_ef so rudely put it
stock sohc axles should handle 200hp no problem
ducsaim
Nov 17, 2010 05:10 AM
Mark80
May 14, 2006 08:01 PM
TurboGoKart
Apr 17, 2006 08:39 PM
LouisM
Feb 17, 2003 11:30 PM
