250 to the wheels!! any one know how??
Old Jul 1, 2006 | 11:11 PM
hatchEG's Avatar
Default 250 to the wheels!! any one know how??
i have a re-built b16a3 motor swap in my 94 civic hatch with intake and exahst i wanna try and puch out 250hp to the wheels i already plan on putting on a turbo and lowering my compression to run more pounds of boost. but i dont really know what else to do help please
Old Jul 1, 2006 | 11:13 PM
Br1anPham's Avatar
Default Re: 250 to the wheels!! any one know how?? (hatchEG)
you dont need to lower you compression. Just slap on a turbo kit and get her tuned. Generally 250whp is not high enough to worry about lowering the compression, you'll be faster with stock compression then you will with lower compression if both setup peaked at 250whp.
Old Jul 1, 2006 | 11:18 PM
hatchEG's Avatar
Default Re: 250 to the wheels!! any one know how?? (Br1anPham)
but im running 10 and 1/2:1 compression i thought that was pretty high
Old Jul 1, 2006 | 11:20 PM
B18C EG2's Avatar
From: Home Of The Players And PIMPS, IN, united states
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchEG &raquo;</TD></TR><TR><TD CLASS="quote">i have a re-built b16a3 motor swap </TD></TR></TABLE>
250whp shouldn't be hard on your "rebuilt" motor at all...buy a kit...slap it on...and have it tuned professionaly.....this will enusre your motor will have no problems at all...
Old Jul 1, 2006 | 11:22 PM
hatchEG's Avatar
Default Re: 250 to the wheels!! any one know how?? (B18C EG2)
yea its pretty quick allready
Old Jul 1, 2006 | 11:24 PM
B18C EG2's Avatar
did you have the motor rebuilt with higher compression..
i'm only asking b/c the american b16 has 10.205320397414986
which is 10.2:1...which is plently low enough
Old Jul 1, 2006 | 11:28 PM
hatchEG's Avatar
the guy i bought my car from said it was runnig 9:1 but he got it tunned to 10.5:1 but i only want that low cause i wanna run 12 pounds of boost
Old Jul 1, 2006 | 11:37 PM
strictly.business's Avatar
Banned
12 psi tuned at 10.5:1 will make more than 250whp.
getting a car tuned wont lower the compression ratio. you have to install lower comp. pistons for that.
Old Jul 1, 2006 | 11:39 PM
hatchEG's Avatar
Default Re: (strictly.business)
ok so i dont even need to mess with my compression
Old Jul 1, 2006 | 11:53 PM
Banned
no.
buy a kit. do research to find out everything youll need.
besides piping, intercooler, turbo, manifold, wastegate and bov. youll need at least 310cc injectors, an aftermarket fuel pressure regulator like a b&m or aem, a fuel rail, a wideband sensor with gauge to montior air fuel ratios and a good tune. you should be making 240-260 at the wheels at 7-8psi with a good tune.
Old Jul 2, 2006 | 02:59 PM
InfraRed's Avatar
how much do tunes normally cost if i were to slap on a kit and take it somewhere...just a ballpark figure
RGSH22ACCORD
Jun 30, 2007 08:05 PM
josh green
Oct 23, 2004 03:03 PM
Nextelbuddy
Feb 6, 2004 10:29 AM
BallHawk3
Jan 24, 2004 08:15 PM
s0liDyNe
Jul 19, 2003 10:24 PM
