250 to the wheels!! any one know how??
Old 07-01-2006, 11:11 PM
hatchEG's Avatar
Default 250 to the wheels!! any one know how??
i have a re-built b16a3 motor swap in my 94 civic hatch with intake and exahst i wanna try and puch out 250hp to the wheels i already plan on putting on a turbo and lowering my compression to run more pounds of boost. but i dont really know what else to do help please
Old 07-01-2006, 11:13 PM
Br1anPham's Avatar
Default Re: 250 to the wheels!! any one know how?? (hatchEG)
you dont need to lower you compression. Just slap on a turbo kit and get her tuned. Generally 250whp is not high enough to worry about lowering the compression, you'll be faster with stock compression then you will with lower compression if both setup peaked at 250whp.
Old 07-01-2006, 11:18 PM
hatchEG's Avatar
Default Re: 250 to the wheels!! any one know how?? (Br1anPham)
but im running 10 and 1/2:1 compression i thought that was pretty high
Old 07-01-2006, 11:20 PM
B18C EG2's Avatar
Location: Home Of The Players And PIMPS, IN, united states
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchEG &raquo;</TD></TR><TR><TD CLASS="quote">i have a re-built b16a3 motor swap </TD></TR></TABLE>
250whp shouldn't be hard on your "rebuilt" motor at all...buy a kit...slap it on...and have it tuned professionaly.....this will enusre your motor will have no problems at all...
Old 07-01-2006, 11:22 PM
hatchEG's Avatar
Default Re: 250 to the wheels!! any one know how?? (B18C EG2)
yea its pretty quick allready
Old 07-01-2006, 11:24 PM
B18C EG2's Avatar
did you have the motor rebuilt with higher compression..
i'm only asking b/c the american b16 has 10.205320397414986
which is 10.2:1...which is plently low enough
Old 07-01-2006, 11:28 PM
hatchEG's Avatar
the guy i bought my car from said it was runnig 9:1 but he got it tunned to 10.5:1 but i only want that low cause i wanna run 12 pounds of boost
Old 07-01-2006, 11:37 PM
Banned
strictly.business's Avatar
12 psi tuned at 10.5:1 will make more than 250whp.
getting a car tuned wont lower the compression ratio. you have to install lower comp. pistons for that.
Old 07-01-2006, 11:39 PM
hatchEG's Avatar
Default Re: (strictly.business)
ok so i dont even need to mess with my compression
Old 07-01-2006, 11:53 PM
Banned
no.
buy a kit. do research to find out everything youll need.
besides piping, intercooler, turbo, manifold, wastegate and bov. youll need at least 310cc injectors, an aftermarket fuel pressure regulator like a b&m or aem, a fuel rail, a wideband sensor with gauge to montior air fuel ratios and a good tune. you should be making 240-260 at the wheels at 7-8psi with a good tune.
Old 07-02-2006, 02:59 PM
InfraRed's Avatar
how much do tunes normally cost if i were to slap on a kit and take it somewhere...just a ballpark figure
RGSH22ACCORD
06-30-2007 08:05 PM
josh green
10-23-2004 03:03 PM
Nextelbuddy
02-06-2004 10:29 AM
BallHawk3
01-24-2004 08:15 PM
s0liDyNe
07-19-2003 10:24 PM
Quick Reply: 250 to the wheels!! any one know how??
