need help on msd blaster 2 coil
do you have an ignition box like an msd-sci or msd-6a?
not sure i fyou can replace the stock coil with a blaster without upgrading ignition boxes.
well i found out how to do it from the MSD website in the forum section, another person had the same question so i just went by that,
the prelude has three wire two on the positive one on the negative. the wires on the positive side are black\yellow and the wire on the negative side is white\blue. all you have to do is run the two black\yellow to the plus side of the MSD coil and the white\blue to the negative side of the MSD coil.
senpai
Nov 12, 2001 09:05 AM
