tranny ground not tightening?
Old Jul 1, 2006 | 05:21 PM
.kyle's Avatar
Default tranny ground not tightening?
how can i tighten this ground on the starter. . it has a locknut. . and the whole wire turns when i try to tighten it . .
thanks for any help
Old Jul 1, 2006 | 05:56 PM
.kyle's Avatar
Default Re: tranny ground not tightening? (IWantATurbo)
ttt helpp!
Old Jul 1, 2006 | 06:27 PM
FERIOkid's Avatar
that would be the power to the starter i wrecken and it is not supposed to be super super tight....
*disconect battery
*hold that wire
*tighten untill the lock washer is compressed and you will be fine
Old Jul 1, 2006 | 06:45 PM
.kyle's Avatar
Default Re: tranny ground not tightening? (FERIOkid)
thanksss!
Old Jul 3, 2006 | 06:59 AM
.kyle's Avatar
tried holding the ground. . locking nut wont turn then . . do i need to break the nut. .? should it be loose from the wire? im not sure because its a locking nut. .
Old Jul 3, 2006 | 07:06 AM
EK79's Avatar
get a new lock nut it may have just reached the end of the threads.
Old Jul 3, 2006 | 07:31 AM
john666's Avatar
maybe a washer to take up the gab if the threads end a bit earily ?
Old Jul 3, 2006 | 07:33 AM
fastwanabe's Avatar
Default Re: tranny ground not tightening? (EK79)
Numnuts thats not your ground. That positive power to your starter. You want a turbo yet you dont even know your car? dumbass.
Old Jul 3, 2006 | 08:21 AM
mattssi's Avatar
Default Re: tranny ground not tightening? (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">Numnuts thats not your ground. That positive power to your starter. You want a turbo yet you dont even know your car? dumbass.</TD></TR></TABLE>
You shouldn't discourage people when he is here obviously to get answers. What makes you think that you have the right to say things like that to other people? You should disconnect for awhile and reflect on your attitude and how far that will get you in life.
Take off the first nut and remove the power wire. then tighten the net that is closest to the starter unit. re-install the power wire and tighten again. be sure to remove the positive battery cable beofre you touch this wire with anything metal.
92eg6_pino
Oct 9, 2010 04:56 PM
bayoufrogg
Oct 24, 2006 08:18 PM
2poor2tune
11
Oct 11, 2006 02:39 PM
Skeletor
13
Nov 22, 2005 11:03 AM
Leets
13
Mar 13, 2002 06:09 AM
